My L19PS monitor, purchased early in 2005, is malfunctioning. The screen frequently goes blank, often related to some activity on the desk such as bumping the monitor, hanging up a telephone, etc. Any slight movement can trigger the problem. The power light on the power button remains on, but the screen goes blank. If I unplug the power plug from the monitor and reinsert it or unplug the power cord from the power supply and reinsert it, the monitor comes back on every time. However, the frequency of the problem means that it is very annoying.
It does not seem to be the power supply and I cannot find any display setting that seems to give rise to the problem.
LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it)
The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display.
If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad.
I have v7 monitor r19w12 which has a dvi output. I ran the cable to the tv (hdmi), however the tv...
(More)
I have v7 monitor r19w12 which has a dvi output. I ran the cable to the tv (hdmi), however the tv reports 'no signal'. I was told V7 does not make its own drivers???? I am using a basic windows driver and I read it cannot recognise the dvi output??????
i have a videoseven L19PS and a ATI radeon X1050 graphics card with a rx480-a Mobo plus Amd athlon...
(More)
i have a videoseven L19PS and a ATI radeon X1050 graphics card with a rx480-a Mobo plus Amd athlon 64X2 dual core processor. every few hours the sreen either goes to big pixels ora screen saying " Out of range h59Khz V120hz Max 1280X1024" .I have set my graphic card refresh to 60 hz the minimum setting on the card and 1280 X 960 but this continues on the left side of the extended screen even when i switch monitors left to right
many thanks in advance
Graham
