Panasonic RV32 DVD player has an H07 error - Televison & Video
  • Anonymous May 16, 2009
    H07 error code
    Novelist:
  • 166 Answers
This code means that the spindle motor did not come up to speed and the only way to fix it is to first find out if its the driver servo circuit thats bad or the spindle motor itself is defective. If you know how to trouble shoot a motor speed control servo sure you can fix it, But theres no easy wand waving fix for this unit. Sorry.
u may try new spindle motor
Posted on Nov 12, 2008
    Sniper:
  • 99 Answers
It's most definately the spindle motor at fault as i've had various models incl. the RV31 with the same mechanism with faulty spindle motors. this seems to be a common problem with these. once i replaced the motors the players worked as normal. hope this helps?
Posted on Jan 07, 2010
MY DVD-RV32 IS SHOWING H07
Ah, the classic H07 error code. It means the spindle motor part of the traverse unit (which also contains the laser) has failed. Because the traverse unit is a multi-operation device, the cost of a replacement could be considerably higher than the retail price of a brand new player, along with the labour costs to configure and align it; therefore making any repairs to this one uneconomical.
If you want to get it fixed, by all means take it to an authorised service centre and get a quote, then you can decide afterwards whether or not to go ahead with the repairs to this one, or buy a new player. It is up to you.
Mar 08, 2011 | Panasonic DVD-RV32 DVD Player
Dvd rv32 keeps saying hot and wolnt play dvds
I think you mean the front display shows 'H07' which means the laser/spindle motor assembly (as one part - also known as a traverse unit) has failed. H07 is a common error code with the Panasonic series of DVD playback decks. Because the traverse unit is a multi-operation device, and because the player is a budget model, the repair/replacement of this part to restore your player back to fully functional condition as well as labour costs could prove expensive - hardly worthwhile. It seems Panasonic have been using substandard components within their products for years now, designed to fail just outside their minimum warranty period.
Feb 10, 2011 | Panasonic DVD-RV32 DVD Player
DVD stops spinning displays code H07. Repair procedure?
H07 is the error code for Disk not Spinning. Open the case, open the DVD rack. Put 2 drops of 3-in-1 Oil on a Q-tip and rub the side of the spindle (located under the optical "eye"). Don't drip! Then close the DVD-rack with a DVD in it. Work the DVD in clockwise direction. Hopefully it will start to spin again.
hope this helps
john
Jan 21, 2011 | Panasonic DVD-RV32 DVD Player
Player stops. H07 appears.
This is a problem with the spindle motor,you can locate where the spindle goes into the motor and spray with wd40 leave for a few mins.
Nov 08, 2009 | Panasonic DVD-RV32 DVD Player
Code h07 comes up when i insert a disk. i have the panasonic dvd-rv32
This is the major deffect design in the spindle motor.
Take the cover out put some WD40 in the spindle motor,leave it soak for about 20-30 mins.should work,after the motor it oil up.
Oct 03, 2009 | Panasonic DVD-RV32 DVD Player
Error code h07
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Sep 09, 2009 | Panasonic DVD-RV32 DVD Player
H07 error msg
This normally means the spindle motor is faulty
Jul 12, 2009 | Panasonic DVD-RV32 DVD Player
Dvd player not working
the dvd i have it blows the fuse what could be the problem?
Feb 03, 2009 | Panasonic DVD-RV32 DVD Player
Error message H07
The spindle motor is defective. Open the cover and see if the disc spins when it loads. If it doesn't, give it a spin in a clockwise direction immediately after loading the disc.
Apr 05, 2008 | Panasonic DVD-RV32 DVD Player
Televison & Video Logo
518 people viewed this question
Top Televison & Video Experts
Electro Med Services...
