Rockford fosgate punch 45HD electrical configurations
5 Suggested Answers
SOURCE: Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
Posted on Sep 02, 2007
  • 31 Answers
SOURCE: Rockford Fosgate Problem in Nissan Titan
some decks save different settings on different sources. Make sure that the bass settings are not up higher on the radio sources and lower on the CD sources.
Posted on Mar 30, 2008
  • 631 Answers
SOURCE: rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Posted on Nov 05, 2008
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
duby1990
  • 367 Answers
SOURCE: Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Posted on Feb 06, 2009
Schematics for Rockford Fosgate Punch 801s amp
I recommend contacting Rockford Fosgate directly. I have acquired much information feom them iver the years. I've been jamming big car audio since 1983.
A thumbs up would be greatly appreciated if this answer is helpful to you. Rockford Fosgate Car Audio for Fanatics
Jan 22, 2014 | Rockford Fosgate Car Audio & Video
Is a boss ce2800 amp a good amp it says its 2800 watt class d mono block
It's over rated on it's specs and they run real hot when working hard. Make sure to located in an area with good air flow and away from material that may melt.
Nov 15, 2013 | Car Audio & Video
I got a rockford fosgate 801s. and i cant find where the fuse is located.
Regards, Tony
May 22, 2011 | Rockford Fosgate Punch 801S Car Audio...
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
I have a rockford fosgate 550 that the fuse blows
Short inside one of the transistors. This requires very good soldring skills and electrical know-how, and some thermal paste to go between the heat-sink and the transistor. Unfortunatly this is not a cheap repair, probably cost around 100 dollars.
Cheers,
Kevin
Feb 09, 2010 | Rockford Fosgate Punch P550.2 2-Channel...
Rockford Fosgate Spare speaker termal screws
if you have one that you can compare to another, go to home depot with that and match it up. If not, take the amp to home depot and get someone to help you find the right one.
Jan 29, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Jan 03, 2010 | Rockford Fosgate Punch 201S Car Audio...
What is the auctual watts fpr the Rockford Fosgate Punch 401S?
rockford fosgate doesnt have watts its considered monoblock it gives off watever the speakers want....it gives them the power they need
Dec 29, 2009 | Rockford Fosgate Punch 401S Car Audio...
I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
LINK
Sep 25, 2009 | Rockford Fosgate Punch 150a2 Car Audio...
273 people viewed this question
 Grubhead
Grubhead
