As I vacuum (which is still working strongly0 the dirt instead of being contained within the vacuum is blowing out both sides from the top where it sits on the bottom canister
SOURCE: emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
SOURCE: Dirt gets caught up in filter instead of in removable container
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
SOURCE: Shop Vac 84M200 Wet/Dry Vacuum does it blow?
This video will show you.
http://youtu.be/-gCukdig57I
