Question about Boston Acoustics XB6 Speaker
Emits a loud hum or rumble sound.
My Boston XB6 subwwofer emits a loud rumble sound regardless if it is connected to the receiver.
This problem is usually because of grounding.
If you look at the power lead, you will notice it is the regular "kettle plug" shape, but it only has two pins (live and neutral). There is no earth connector.
You have to ground the sub to your receiver. This is done by running a RCA connector connected to one of the unused connections to the amp.
However, this doesnt ALWAYS solve your problem. As in my case. I have a Pioneer 7.1 receiver, which is ALSO not grounded. so running a spare RCA cable has no effect. What I have done is wired a RCA connecter to a copper cable and connected the other end to the Earth pin on a 3 prong plug. This is plugged in to a wall socket, thus grounding the sub.
It's not a solution the manufacturer will suggest, but it seems to work for me.
Posted on Jan 06, 2009
Loud humming sound
Make sure that the input connection ground is good. If that does not cure the loud hum then you have a power supply issue.
Oct 27, 2015 | Boston Acoustics Boston Acoustic Micro...
How to fix loud sounds from my subwwofers
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What loud sounds? Feedback, or bass boom?
Jul 13, 2014 | Audio Players & Recorders
Loud HUM from 1963 Wurlitzer 2710 when plugged in
If you observed a vacuum tube with the symptoms you describe, it requires replacement but there may be other failed components as well.
Dec 27, 2013 | Audio Players & Recorders
Dewalt dw9118
First I question what's the charger doing for whatever you are charging or is it charging? I would say if the only problem is a hum and all else is OK then don't worry, let it be.
Aug 24, 2013 | Black & Decker Tools & Hardware - Others
Humming noise and vibration when steering left
bad cylinder, low fluid in your rack and pinion
Apr 26, 2012 | 1995 Pontiac Grand Am
What is it when you have power and hear a fairly loud hum< or buzzing... but no sound??
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Jan 03, 2011 | Boston Acoustics BA745 Computer Speakers
I get a rather loud rumbling sound when I first start up the dryer the drum is turning but still getting the rumbling sound but not as loud.
Sounds like you need rear rollers or you have a bad blower wheel. If you turn the dryer off and still hear the rumble for a few seconds its the blower wheel. If the rumbling stops instantly then you have bad rear rollers. Hope this helps.
_MJ_
Dec 14, 2010 | Maytag Dryers
Very loud hummimg and crackling - even when volume turned down.
There are a few variants for this model depending upon the serial number. From your description, there are some capacitors in between the amp stages called coupling caps that are failing. The hum is some DC current being passed through the output stage. The crackling is probably just dirty controls.
Dan
Aug 18, 2009 | NAD Audio Players & Recorders
Boston Acoustics XB6 Speaker Logo
362 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
