can you help, i bought a blackberry 7100v from e-bay, it asks for an unlock code, how do i get round thi, as i do not want to enter a password every time i use my blackberry
need to remove the itpolicy with the desktop manager!
Method 2: Placing Blank IT Policy on the Device (OS 4.2 and earlier devices)WARNING!
Follow these instructions only if you know what you are doing. These instructions can actually downgrade certain BlackBerrys' abilities (i.e. permanent loss of support for Bluetooth keyboards) if your BlackBerry actually does not already have an IT policy installed. These instructions are meant as a last resort to regain BlackBerry capabilities, in the event your BlackBerry is encumbered by a restrictive leftover IT policy after removal from a BES (i.e. eBay purchased BlackBerry). Steps to Method 2 removing IT Policy.
This procedure should ONLY be used on devices that cannot be upgraded to OS 4.3 or higher. If you have an 8xxx device then use the method described above. If you have an older 7xxx device or have OS 4.2 on the device then continue with the following instructions. This is a How-To for removing IT policy from your BB. In essence, what this does is apply a blank IT policy to the device. The blank IT policy does, unfortunately, leave some IT policy firewalls in place, however. For instance "keystroke injection" is set by default to "deny" on most IT policies. This blank policy won't give back "allow" for this feature. This becomes a problem if you desire to use a Bluetooth keyboard. You'll be unable to use the keyboard. If a way is found to get this back then I'll edit this post accordingly. A quick check to see if your BB is under IT policy can be done by going to Options/Security on your Device. If you see any references to IT Policy whatsoever, then you have a potentially restrictive IT Policy that can be removed.
Step 1: Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here.
Step 2: Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). Click Here to Download
Step 3: Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest OS for your device. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts.
Step 4: Close the Desktop Manager if it is open.
Step 5: From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin
Step 6: Open the Desktop Manager.
Step 7: Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications.
protege luggage lock tsaoo2-- haven't used lock in over a yr. unfortunately stored locked. How do I...
(More)
protege luggage lock tsaoo2-- haven't used lock in over a yr. unfortunately stored locked. How do I unlock and reset my lock.
what is the setting for the wireless currently wifi not working but it has in the past until someone...
(More)
what is the setting for the wireless currently wifi not working but it has in the past until someone played with the settings now I need to retrieve those settings so that I can get wifi where free wifi is offered.
iphone is locked it says waiting for activation may take some time
The sliding bar does not...
(More)
The sliding bar does not move to open the phone
how do i find setup wizard on my blackberry curve 7100v , i cant find it anywhere.... aslo i cannot...
(More)
how do i find setup wizard on my blackberry curve 7100v , i cant find it anywhere.... aslo i cannot send messages via pin to pin...... can u help
