Question about Kenwood Sirius KDC-MP925 CD Player
Initialization Problem KDC-MP925 in 98 VW Jetta. When the ignition is switched on, the unit doesn't open on its own anymore, the spot on the faceplate needs to be pressed. About 90% of the time, it will open halfway and then stop without powering on. When the SRC or faceplate spot is pressed again, it goes through an up/down in/out cycle and then usually stops again. After repeating the process a number of times, eventually it comes on and works fine. Sometimes during this process, the buttons light up, but there is no display. Sometimes I can remove the faceplate and everything returns to its OFF position with the DSI blinking, sometimes not. All ribbon cables appear to be intact, and I'm fairly sure they're OK as everything works when it does come on. The only thing that acts funny is the up/down panel control. Once it's moved to its lowest position, the up/down won't adjust anymore and will sometimes cause the unit to shut down with everything remaining in the open position. The same thing habbens with a different mainboard, so I *think* I've got it narrowed down to the sub-assembly that is responsible for moving the lower control panel, but I'd like to hear the voice of expreience before I start throwing parts / money at this thing.
  • Anonymous Jan 26, 2008
    hi
    i got the same problem with a kdc-w8027 (same modele) and i canty find any solution all rubon are ok dont understand.
    thank for help
  • Anonymous May 11, 2008
    ignition turned on gotta push button to open faceplate..no display or lights then shuts off
Hi, I'm not an expert but if you phone 0113 202 1040 a company called unicar - they have a specialist repairs department that may be able to help you. regards
Posted on Nov 12, 2006
97 VW JETTA WONT START WITH KEY. BUT I CAN PUSH START IT. WHATS WRONG?
These cars are known for having bad Ignition switches.
Replace Ignition Switch
Nov 30, 2013 | Bosch Vw Jetta 2.0l W/ac 70a 94 95 96 97...
92 vw jetta,wont start,runs for3 seconds,when i turn ignition switch on,nodash lights,only battery light appears,no other lightslightup like before,locks work,dont understand what to do now
Is this a 92 Jetta like you describe or a 02 Jetta TDI? If it's a 92 Jetta, I can almost guarantee the ignition switch is bad. Common failure. They're cheap, but require special tools and experience to remove.
Oct 15, 2013 | 2002 Volkswagen Jetta TDI
1997 vw jetta will not start after battery disconnect
Double check your connections to make sure you have the cables connected correctly. Check the owners manual to see if there is an initialization process you have to follow after connecting the battery. In most VW the connection process recommends connecting the positive then the negative terminal and if that sequence isn't followed it doesn't like to start. It makes no sense but in some cases that is the only way it will work.
Apr 30, 2011 | Volkswagen Jetta Cars & Trucks
Vw jetta 1995 2.0 having problems with the turn
TELL ME WHAT PROBLEM YOU HAVING.IF TURN SIGNAL LIGHTS DONT WORK YOU CHECK BULBS + SOCKETS AND THE FUSE.IF ALL OKAY PROBLEM IS IN FLASHER UNIT SWITCH OR LOOSE OPEN WIRE CONNECTION.IF EVERY THING CHECK OUT GOOD TURN SIGNAL SWITCH IS FAULTY.
May 26, 2010 | 1995 Volkswagen Jetta
Need instructions on how to replace ignition switch? on a 98 vw jetta gls
ARE WE TALIKING ABOUT THE KEY CYLINDER OR THE ELECTRICAL SWITCH?
Oct 01, 2009 | 1998 Volkswagen Jetta
Airbag lamp stays on a 98 VW Jetta,
you need diagnostic equipment.
marko
Sep 21, 2009 | 1998 Volkswagen Jetta
My 1998 VW Jetta GL - Ignition Switch
It could just be out of adjustment. I recommend going to a dealership for the part. The VIN number should identify your car specs exactly to avoid getting the wrong part
May 11, 2009 | 1998 Volkswagen Jetta
1996 vw jetta break light on
Yes. Check the brake fluid frist and see if the light goes out
Mar 12, 2009 | 1996 Volkswagen Jetta
Kenwood Sirius KDC-MP925 CD Player Logo
201 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
