Question about Sanyo PLV-Z3 Multimedia Projector
Z3 will not startup after lamp replace....
Replaced lamp without touching anything else.Picture was unclear. I turned of and saw (after everything was cold) by coincidence that lamp was not correct mounted in lamphouse (around 2 mm wrong at top - Ok at bottom).  Now it won't start again. Indicator on top says replace lamp with green colour - but lamp is definately OK. Are there any "overheating" control procedure or anything else that has to be "set-to-zero" or similair...before starting up?Please help - just now looking TV on pc :-( Bent from Denmark
  • Anonymous Jan 18, 2009
    I've got the same problem. Sometimes it works and then it won't.
  • minibossmike Apr 02, 2009
    Me too. Got new lamp, put it in correctly with no problems.  Lamp will only light up 1 out of 12 trys, else it just flashes replace lamp light.  Also, I hear a small buzzing sound for about 4 sconds right after powering on.
  • 43 Answers
You need the full service schematic.
I had your exact problem, and solved it with the manual.
You can get the manual, free here
http://yama.co.za/forum/index.php?topic=147.0
Posted on Dec 03, 2009
Thomson 50DSZ644. Just replaced the Lamp great picture but burned smell.. after few house it smelled verry bad..and i turned off. now when i turn on the tv the picture in middle is dark and still thi
should have unplugged it when you noticed the smell.
UNPLUG and remove and look at lamp you installed--is something in the housing where lamp goes melted? I hope you did not touch the face of the bulb with your hand or fingers.
What ever is wrong find it before trying to use set again.
Dec 22, 2012 | Thomson 50DSZ644 50" DLP Rear Projection...
No picture w/sound and controls on front panel don't responed
The technician you saw was correct, most likly it wasnt the lamp by istelf something in the circuit board caused the lamp to go out, you only replaced what was the results of what went wrong.
Nov 13, 2007 | Samsung HLP5085W 50" Rear Projection...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
Tv will not turn on
For dark picture I need to ask one question, How long ago you replaced its lamp? one year, two years?
Picture brightness is depends on lamp in LCD rear projection (DLP) TVs and if lamp got weak in generating light, you will see dark picture.
I would recommend to replace lamp and buy Sony original lamp from Sony Accessories Store.
Required lamp part number is as follows..
F93087500 LAMP BLOCK ASSY XL-2400
and price is $200
Good luck.
Apr 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony kf-60we610 washed picture
if everything including sony menu is unclear, yeah cleaning may help. dirt can get inside the engine too. look at a white screen, this is your answer (or a black in some cases). any dirt on mirror or lense will be uncolored distortions. colored distortions are inside the light engine.
Nov 02, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Unclear picture
Vertical line if in the menu also will need a panel if no need an small signal board.
Jun 07, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sanyo PLV-Z3 Multimedia Projector Logo
183 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
