Question about Dell Inspiron 2200 Notebook
I PLUG IN A BRAND NEW WESTINGH. HARD DRIVER 160 GB AND COMPUTER S
I HAD A 40 GB HARD DRIVE PUT IN SYSTEM/ SYSTEM SHUT OFF.
TRIED A NEW 160 GB HD. SAME PROBL. TRIED AN OLD
486 K HD /SYSTEM STAYED ON BUT NOT ENOUGH STORAGE
FOR WINDOWS 98. SOLUTIONS PLEASE
    Genius:
  • 1,605 Answers
Did you configure the 160GB hard drive as second???
there is a shorting pin between the ribbem cable and the power cable.
take a look on the hard drive, there should have adiagram shows where the shorting pin need to go to make it as secondary drive.
install the hard drive as secondary drive.
if you want the drive to be the primary. you nee to install the operating system on it.
with out operating system the machine will boot up in to DOS only, and a error message telling you the drive has no loader.
Posted on Nov 12, 2008
Toshiba 160 GB usb hard drive, has clicking sound when powered up. Computer(s) don't react to unit when plugged in. Power light only indication unit is plugged in.. Suspect drive head stuck in protected...
Clicking sound is the motor trying to move the head. Unplug it and try gently tapping it from the side, it seem to help time to time with some drives. If that doesn't work, put it in a zip-lock bag and freeze it for 40 minutes and try again. If still doesn't come up, you're out of luck.
May 31, 2010 | Toshiba 160GB USB 2.0 Portable External...
Installed 500 gig drive with Windows XP. Computer only recognizes it as 127 gig.
You need to go to your computer manufacturers support-driver site and look your model up, then put in your operating system and search for drivers. In the drivers column, you need to find the download for an updated BIOS. Download this file and run its self-executable program and flash your systems BIOS. The new BIOS will allow your system to see large hard drives...right now your system has a limit of 132 GB.
Jan 15, 2010 | Western Digital Caviar SE16 (WD5000AAKS)...
Samsung DVR HR 737 substitution Old original Hdd 160 GB (dead)
DVRs, not sure at the moment about the one you have, are limited with the brands and size hard drives it is able to accommodate. I'll advise you to check the manual you have with the DVR to see the brands and sizes that it can accommodate.
Sep 24, 2009 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Lacie HD power light flashing yellow and orange
Hi. Sometimes, there are compatibility issues on external drives. Most recent computers will read them while others may not. Either the external casing or the cable is causing this.
Aug 27, 2009 | LaCie (300728U) 250 GB Hard Drive
Computer not recognizing external HD
1st try a different computers make sure its not your Hard drive!
2nd if that works then go to the hard drive maker and download a software driver for it that should fix the problem
Aug 10, 2009 | SmartDisk FireLite 40 GB Hard Drive
New hard drive reloading oc
Hi Amy,
It really depends if the notebook is capable of supporting 160 gb HDD or not.
It case it is cabable call Hp and order anew set of Recovery Cd and it would work fine.
Apr 27, 2009 | HP (PV944A) 160 GB Hard Drive
Cant partition my external HD
try using diskmgmt.msc (from run) diskmanagement utilty or the partition magic software to format that would certainly help you
Feb 19, 2008 | Transcend (TS40GSJ25) 40 GB Hard Drive
Drive terminators
Translate from portuguese to english... Meu HD também estava com este problema, o que fiz foi limpar o contato que liga a placa lógica do HD ao leitor do disco rígido que estava oxidado. O problema ficou resolvido.
Dec 27, 2007 | Samsung (SP0411N) 40 GB Hard Drive
My computer stopped detecting my hard drive
Hi, Based on your post/description: 1. Tried on 3 different computers - no go, so it's not a PC problem; 2. Tried replacing the cable - no go, so it's not an interface problem; 3. That leaves you only with the Firelite itself. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it direct to a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 03, 2007 | SmartDisk FireLite 40 GB Hard Drive
Dell Inspiron 2200 Notebook Logo
67 people viewed this question
Alun Cox
