Question about Air Tools & Compressors
Air stapler leaks air through ''nose''
It's a little Husky (Home Depot) 60-psi max stapler/brad nailer combo tool. Little compressor (1 gal). Was using stapler with 1/2" 18-ga. staples, was working fine. Fastener tool suddenly started pouring air through the spot where the fastener comes out. Can it be fixed? HOw?
  • 4,234 Answers
This sounds like one of the O-rings has failed. Yes it can be fixed. Check to see if HD has an O-ring kit for these guns. That kit will contain all of the O-rings as well as the lubricants for a total rebuild. That should resolve your problem.
Dan
Posted on Nov 13, 2008
What kind ryobi p300 staples & brad nails
Nice little nailer Fred. Here are the details (sold at Lowes or other lumber centers).
Staple Size 3/8 in. Crown Width, 1/4, 5/16, 3/8, 1/2, 17/32, 9/16 in. length
Brad Size 18 gauge, 3/4, 1, 1-1/4 in. length
Magazine capacity 100 staple/brad Good luck with your projects
Oct 14, 2011 | Ryobi P300 One+ Stapler Brad Nailer
Does the campbell hausfeld model sb504000 2 inch nailer/stapler need an external air to get started?
Sb504000 works just fine with pressure range from 60 to 120 psi depending on material. Any small compressor will work great. Using the gun at max pressure will shorten the life of the gun. Best practice is to set pressure to just under 100psi for most work and increase pressure when nailing hard wood. Using at max pressure will strain the driver and the lower part of gun (screws that hold nose to body). Some hard woods will bend an 18 gauge nail. Good luck with your gun and have fun with your projects.
Aug 11, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
Can not drive nails. Loud air hiss at top on tool
you have an air leak and you have to fix your stapler nailer hope its not cracked but just a seal
Sep 24, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
I have a poter cable brad nailer and after running
Sounds like a trigger seal. I assume this is an oil-less brad nailer as that is the standard. You should be able to find the seals at any local hardware store including Home Depot or Lowes. If you can't find the portercable O-rings just grab the random assortment from Bostitch which is usually readily available. Refer to your parts manual for the correct size/gauge
Apr 15, 2010 | Porter Cable Cable Brad Nailer and...
Need Manual for Husky Model 41214 Air Compressor
You can get the manual for model 41214 from my dropbox area:
http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
http://db.tt/vQycqXIW
Thanks,K
Dec 20, 2009 | Air Tools & Compressors
Hi. I just bought one and can't figure out how to get the pressure to start increasing? the power runs ok but the pressure is still at 0. thx
you could check the bleed valve.
it is located under the tank,
put on the unit and place your hand over the valve,
if there is air coming out of it then that is your problem.
some valves are made to tighten and some are made
to loosen. important stop the air from coming out.
if that is not the problem contact me for a next tip.
Dec 07, 2009 | Makita MAC7002K Brad Nailer,Stapler & Air...
BN200A porter cable brad nailer. have tried
check for a broken driver blade, also make sure of the proper nail guage for the tool. Let me know if this is not the case and I will find you a breakdown for the tool for further inspection.
Nov 06, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Describe your Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit ProblemCompressor builds to 80PSI and will not shut off or build...
sounds like an air leak of some sort. when you get it up to as high as it will go, turn it off and listen for an air leak. Let me know where it is leaking and i will tell you what to fix
Jul 13, 2009 | Stanley Factory Reconditioned Bostitch...
Will only charge to 40 psi, is supposed to charge to 150
You may have a problem still related to the original reason it was reconditioned.
However, you should have a regulator that you set to the tank pressure you want to maintain. Most have a tool regulator as well and 40 psi sounds like that is what it is set for.
If you do have a tank pressure regulator and it is still not charging above 40 psi, then either take it back or pick up a new regulator for under $20 at Home Depot and replace the gauge you have now.
Also, sometimes the gauge will have a needle tilted so that one end presses against the glass, and if you tap the glass hard with your finger it will move on around to the correct pressure.
Finally, if you are not experienced with small compressors, look under your gauge and see if there is not a black knob that pulls out and pushes in to turn and change the pressure.
Sirwriter
May 21, 2009 | Stanley Factory Reconditioned Bostitch...
Air Tools & Compressors Logo
587 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
