Bios does not recognise the correct amount of memory inserted!
    Sergeant:
  • 207 Answers
The most likely Culprit is an integrated (Built into the motherboard) or OEM (Original Equipment from Manufacturer) Video card that is "Borrowing" some of the system memory to provide video Memory.
This can happen EVEN if you have a standalone retail card, if the integrated one is still enabled in the BIOS (Basic Input Output System)
To resolve this open the BIOS (Usually pressing <Delete> or <F12> during the boot up process
search through the menus until you come to the settings for your onboard Video card. If you have a standalone card DISABLE the onboard video. If you are using the integrated video then you should be able to adjust the amount of Memory you want to allow the Video card to "BORROW"
If the above situation does not apply to you, please let me know some more information about the problem so that I may assist you further
Thanks
Dave
Posted on Nov 12, 2008
The amount of graphics card in built in Intel motherboard dh55pj
The amount of memory used is deducted from your total installed - the memory chips that are inserted when it was installed. The amount can be changed by entering the BIOS configuration and setting the amount manually.
To have better quicker graphics, the motherboard graphic system would have to be disabled and you would need to purchase a PCI or PCIex add-on video card.
Sep 13, 2011 | Intel DH55PJ Motherboard Bundle...
There is a slot for camera memory cards but when card is inserted the computer doesn't recognize it
If it has a large amount of memory it won't recognise it eg if it's above 512mb eg 1gb ,2gb ,4gb 8gb card.
Aug 03, 2009 | Dell Inspiron 6000 Notebook
Inspiron 2200 Memory Module not recognised
Are you sure its the correct speed/type of RAM? According to Google your laptop takes PC2700 DDR RAM, ensure you are using this in both slots to avoid problems. If you have it fully inserted into the slot and nothing happens when you swtich it on then the laptop doesnt like that type of RAM and you'll need to change it.
May 17, 2009 | Dell Inspiron 2200 Notebook
The 256MB SDRAM is showing as 128 MB SD RAM
if you have onboard graphics card that shares the ram memory with your graphics card then the configuration in the bios will determine how much memory is shared with your graphics card so you will lose memory there. Also windows xp does not always report the correct amount of memory so check with cpu z or wcpuid or another utility to check.
Also when you restart your computer when it detects the memory how much does it show that is installed there or if you go into the bios does it show the correct amount.
If it does not then it is not compatable and I would suggest going to www.crucial.com and selecting / getting the correct memory by selecting the correct computer / motherboard that you have.
Apr 10, 2009 | Computers & Internet
Only recognises 2 gb when max supported is 4gb...
Is it all the same exact brand of memory, Dual Channel or no ?
You said its 800mhz ram and the mobo supports 600mhz, is it all 800 or 600 mhz or different speeds. Alot of motherboards will kick it down to match the other sticks some might not.
Jan 04, 2009 | ASUS P5RD2-VM Motherboard
Usb port not recognising devices and mouse pad not responding
hello there. It sounds as if your motherboard (bios) is not configured correctly, or your windows drivers somehow got corrupted. check in your MoBo's manual to see how to access it's bios options. and make sure that your onboard usb options are enabled.
Nov 23, 2008 | Microsoft Computers & Internet
Installing memory upgrade
No.
Once you install the memory into the slot the BIOS will update the memory configuration during the bootup proccess.
You can check to see if your new memory has been fully recognised by double clicking "System" in control panel.
If you check the amount of memory in System before the install and compare it afterwards you will know for sure if the memory has registered correctly.
Aug 03, 2008 | Dell Dimension 3000 PC Desktop
Memory
You didn't give any details, but here is an answer to a common misunderstanding:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=BF4C8393BFC74A83B9EC318630B9CE7D&doclang=en&cs=
If this isn't your problem, the please post details for us to research
Jun 14, 2008 | Computers & Internet
Ram gets detected only to half of the value specified
dear pradhan
your ram 256 but i think your ram memory shared with disply memory so . first restart your system and press DEL key untill u enter in bios setup.then go tothe advanced option and disable graphic memory then save settings and restart pc . your problem is solved.
Mar 18, 2008 | Intel SuperMicro SUPER Motherboard - 810...
New memory not recognised when installed into spare slot
"Put it in and reboot"... be sure the aptop is OFF when you add memory! Otherwise, you can damage BOTH memory and laptop! Once memory is installed there is no "trick" to get it recognized. If it is good and meets the BIOS specs, it will be recognized and registered after a cold boot.
1. Be sure the memory is inserted properly (both clips on the sides are flush with the half-moon tabs between memory and metal clips).
2. Sometimes on a memory slot that has been empty a long time (and gets a bit corroded) it is a good idea to insert the memory, remove it again and reinsert 5 or 6 times (only) to clean the contacts.
3. If number 1 and 2 have been done, and you still have this error, then there is a problem with the memory:
It may be the wrong speed (PC100 instead of PC133, etc)
It may be too LARGE for the BIOS to use (all laptops have maximum memory per slot specs that must be observed, because the laptop cannot see memory that is greater than its specified capacity.
In any case, check the manual or the website for your laptop, to get the specifications for memory type AND capacity per slot, and TOTAL memory if you have two slots -or memory soldered on board).
Feb 10, 2008 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
