Question about Sony MHC-GX450 CD Shelf System
Sony MHC-GX450 On boutton flahing red system unresponsive
Tried the un plug and plug in and the 3 button push methods per the manual. Read most of the responses at Fixya including the removing of white band connector air blow clean and re-insert. Have not tried yet.
But how do I know if it is the fuse? Where is it located and how to I change or reset the fuse? unable to find anything on fuses in the Manual.
Also where is the voltage switch I've seen mentioned but nothing in manual.
Thank in advance for your assistance. -Bob C.
    Genius:
  • 1,142 Answers
The volatge switch is located near the power cord at the back panel..
Posted on Nov 12, 2008
    Brigadier General:
  • 6,966 Answers
Initially, I doubt if it is the fuse. If it were, the unit would not even have the flashing red light. The standby light or the red light flashing indicating that the unit has switched to protection mode., the unit in its self diagnosis has detected a fault. In order not to extend the damage, the unit prevents itself from turning on. On some models, the number and sequence of flashes indicates the general area of the fault and where initial diagnosis can begin. Eventually the unit has to be opened up for a look and see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Incidentally, in the hope that this is a simple glitch, perhaps you can try unplugging from the mains and removing all connectors. After an extended period, reconnect and verify connections and try again.
Additionally, was there anything out of the ordinary prior to the incident such as power failure/interruptions, thunderstorm, TV used for an extended period pf time, the remotes has been inadvertently played with, or anything noteworthy.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
My subwoofer for my sony mini component system mhc-gx450 will not work any sugestions???
Is the LED on the front of the subwoofer unit glowing?
If not then check that (a) the plugs are correctly inserted in the two sockets on the back of the the mhc-gx450, and (b) check that the subwoofer is activated on the mhc-gx450 unit.
Oct 15, 2011 | Sony MHC-GX450 CD Shelf System
I have no clue how to hook up my acer computer to a sony mhc gx450. Please include all the wires i need.
http://www.retrevo.com/support/Sony-MHC-GX450-manual/id/268ag305/t/2/
Look up "Hooking Up Optional Components" and assess what your PC's audio and video capabilities are that would use the Game Inputs. The Sony end accepts standard RCA pin cables x 3. Adapters are available at any electronics store to match your PC to that. Within the PC you need to configure the audio via whatever Sound Controls are in charge.
Jul 11, 2011 | Sony MHC-GX450 CD Shelf System
My stereo wont read any CDs and i've tried all of the manual suggestions. SS-RG444
Have you tried cleaning the laser. If you are not familaiar with electronics, try using a "CD Cleaning Disk" from walmart or kmart or most anywhere!
May 30, 2010 | Sony MHC-GX450 CD Shelf System
Sony mhc-gx450 cd player is not reading.I used a cd cleaner and d
First unplug the unit and press the power button to make sure all the power is out of the unit. Try to take a cotton qtip and clean the lazer lense with alcohol. after wipe it clean with a new cotton qtip to remove the film the alcohol produces. Do not use a lot of alcohol and drip it all inside of the unit though.
Also if you tried a cd-r try a real copy instead. Make sure your cd's are ok.
Good luck.
Feb 15, 2010 | Sony MHC-GX450 CD Shelf System
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
Jun 24, 2009 | Sony MHC-GX450 CD Shelf System
How do I connect ipod to sony MHC GX450? can i hook my ipod to my sony mhc-gx450
yes you can connect using rca phone jack to rca jack it depend on what cable you use from your ipod. connect from your ipod audio output to auxillary of sony mhc-gx450.
May 31, 2009 | Sony MHC-GX450 CD Shelf System
Sony MHC-GX450 On boutton flahing red system...
I have the same problem.Power button blinks red constantly.
Nov 13, 2008 | Audio Players & Recorders
Hello
Un Plug It for like 10 to 20 seconds and plug it in it should work it happens to me all the time if it contionuls check the speaker wires and see if the wires are toching together that will be the problem to
Oct 27, 2007 | Sony MHC-GX450 CD Shelf System
Sony MHC-GX450 CD Shelf System Logo
289 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
