Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Calypso ''ob'' problem
My Worlpool Calypso stopped spinning and draining and there is a "ob" on the display. I took out all the clothes thinking ob was for out of balance - still doesn't work. 2 repair men have come to fix, and just told me to buy a new machine. !!! Someone help
  • 65 Answers
Ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
if this does not fix the issue it is most likely the strut and shock system that is falty on the machine. you could replace them yourself but they are fairly expensive
Posted on Nov 29, 2008
Washer keeps shuting off in the spin cycle and the code ob shows up.
Hi
Thanks for using FixYa. Error ob indicates off balance, if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an “ob” for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load. Press STOP/CANCEL to clear the display. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
WATER DOESN'T DRAIN OUT OF WASH TUB. Discovered and removed bra wire and clog from riser tube. Display reports out of balance "ob" during spin cycle, yet there is no laundry in tub. More clog somewhere? ...
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&*@#%%
Jul 03, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
Water is draining but doesn't drain the lower basin. shows ob, sl, or ld on readout. Have to unhook drain hose - let it drain then it will usually start working properly.. when the basin is full and it...
Hi There
I'm giving you the coeds that you need. So i hope this helps you and let me know how it goes.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance
Press STOP/CANCEL to clear the display. S Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Heelo, during the spin cycle the washer stops and
Water not draining from the tub. Check for hose crimp ir clog. Here is your manual codes on page 19.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/8566930.pdf
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
May 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso GVW9959K washer with OB code
This is a common problem with the Calypso washers. The problem that you are having is related to the pump. There is something in the pump that is causing the error code to occur. Since the pump isn't working right all of the water isn't draining out thus causing it to be out of balance. If you can get down to the pump and check it out chances are you will find something in it. It might just be some fabric or string from clothing caught around the pump motor. Just make sure you clamp off the hoses or you will flood your laundry room. Once you clear out the pump unplug the washer and wait a few minutes before plugging it back in. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad I could help.
Jan 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso Washer troubleshooting
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^#@#$%
Jan 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD and OB on Calypso
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating
OB:
Basically, it sounds like your drain pump is bad or clogged, and the extra water is throwing the spin cycle off balance
-Perry
800-Appliance San Diego
Dec 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
447 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
