Question about Sony CMT-CPX22 CD Shelf System
CD tray doesn't open
Hello I bought this new system two days ago and I never managed to open the CD tray since. The disply shows "Open" and the system really tries to open the tray two to three times, but it will not open. I turned everything off by the plug several times and waited a couple of minutes until the next go. Everything else works perfect. Do I have to "unlock" the tray in some way or is it a known technical malfunction? Any help is much appreciated Thank you
    Scholar:
  • 119 Answers
If the unit actually tries to open but does not, it is not locked. a locked unit does not even try to open. it sound like a mechanical misalignment. take it back to get a new one, since it's only 2 days old.
Posted on Nov 13, 2006
SOURCE:
My dvd burner wont open
on the drive there should be a small hole open up a paperclip and insert it this fill push against the cd frame and open the tray
Nov 06, 2011 | Computers & Internet
Can't find CD icon is missing from one computer
Windows Key-E will bring up windows explorer which should show your list of available drives.
If this doesn't show your CD drive then try removing CD from drive. Does the disc tray open? If so then reboot system without disc and try the above method to find cd-drive.
If this doesn't work you may need to involve more hands on trouble-shooting.
Thanks
Jul 22, 2011 | Staples 2x1 USB Peripheral Switch
I have got a Sony CMT-EX100 Micro System. When I touch the OPEN/CLOSE-button on the top, the system doesn't open. I opened the system and it seems that the magnetic disc-holder holds the disc-tray too...
This problem is easily repaired! The belt that drives the mechanism is worn out (relaxed) and slides on the motor pulley. Just open the device (from the bottom and then drag the body up by removing the edges). You have to put a new belt section ø 35 mm 1 mm and the unit will work again.
(hello from France)
Jun 05, 2011 | Sony CMT-EX100 CD Shelf System
I have a HP dvd/cd rom rw 1040d disc drive. The disc tray doesn't open when empty. It tries to open but doesn't manage to open. If I manage to get it open, (Usually manually when shut off, it will open...
Premature failure of this drive appears to be a widespread issue. I have joined in a support thread at HP and encourage you to do the same:
http://h30434.www3.hp.com/t5/CD-DVD/Hp-dvd-1040i-Disk-tray-doesn-t-open-half-the-time/m-p/347544#M1980
Sep 29, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
Unable to Open F61 error flash on screen
TIMING ADJ...AC DISCONNECT !!
OPEN TOP LID
CHANGE MAIN BELT BY MOVING THE TRAYS.
PLUG IN AND CHECK
IF NOT NEED ADJUST TIMING FOR THE WEELS.
ONLY EXPERTS
FREDDY.R
ISRAEL
Nov 11, 2009 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
CD tay won't open
If you had any cds inside, you can open the case and see whether there's any cd jammed, with the power switch off! If you didn't have any cds inside, open the case anyway and check if the tray opens or not!!!
Hope it goes well!!
Apr 04, 2008 | RCA RS2653 Shelf System
Cd door won't open
I just bought the same system a week ago and my stereo door is completely broke and the cd peice doesn't eject
Dec 31, 2007 | RCA RS2664 Shelf System
CD Carousel for the Onkyo Shelf System
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Oct 11, 2007 | Audio Players & Recorders
Disc tray won't open
needs new tray drive belt
Feb 08, 2007 | Philips FWP900 System
Open Questions:
Sony CMT-CPX22 CD Shelf System Logo
370 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
