2001 Mazda Tribute Logo
Posted on Nov 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine Died on Reverse Gear
When I shift from the Drive gear to Reverse, my engine stopped completely. Then I shift to Park to start my car, the engine made was loud and just kept getting louder and louder until I shifted to Drive. The noise has happend quite a few times lately where I shifted from Drive to Park. Do you know what's happening to my car? I have a 2001 Mazda Tribute DX V6.
Many Thanks!
  • 2 more comments
  • Anonymous Mar 13, 2014
    the car will drive in d for like 100 meters and the transmission will stop working but will drive ok in reverse and in second and in low
  • Anonymous Mar 16, 2014
    Some times car shifts rough and when you shift from park to drive or reverse it bangs into ge
  • Anonymous Mar 22, 2014
    car will not shift in to gear after stopping until I turn the engine off and then on again, it seems to happen after driving more than 30 miles
  • Anonymous Mar 28, 2014
    The speedometer quit working too. It moves up and back when I start the car but it will not show me how fast I am going, will not move when driving. This happened at the same time. Won't go over thirty, won't change gear while driving and speedometer won't work. It is an automatic. I can hear the engine get louder when I give it more gas but it will not go faster.
bobkelsey
Level 2:
  • Expert 46 Answers
  • Posted on Dec 01, 2008
bobkelsey
Expert
Level 2:
Answers
46
Questions
0
Helped
32584
Points
128
Try adding some transmition fluid to the transmition . or have it towed to a repair shop
I have a 2004 Dodge Dakota, V6, 3.7L, with the 42RLE transmission. The tranny died last week, and I have replaced it with a used 42RLE from an '05 Dakota. Shift lever on steering column in park. Shift...
I recently had my engine replaced in my 2002 grand marquis 4.6 with a 2009 crown Vic 5.4 engine and was running fine until I broke my ignition and tried to replace it myself I bought a new ignition switch didn't work so I bought a steering column and still won't start what do I d?
I landed on this website reliable-store.com and they got me free manuals so I used it to repair and it works fine
After ideling a while i try to shift into reverse or to drive and it always dies .......any tips or ideas?
engine dies when shifting into reverse or drive - Third Generation ...
www.thirdgen.org/forums/tbi/346079-engine-dies-when-shifting.html
Feb 11, 2006 - engine dies when shifting into reverse or drive ... After it dies it starts right up and idles fine in park or neutral. ... these ignition items because you weretrying to cure the stalling, or, did the stalling occur after you replaced these items? ...The only thing that kept the car running was adjusting the Idle screw up.
Engine Dies When Placed In Gear***Split from Spittybug...EFI ...
dmctalk.org > ... > MAIN FORUMS > Custom DeLoreans/Mods > EFI
Jul 5, 2012 - 18 posts - ‎4 authors
Just to give an update on my car - I've been having an issue with the car stalling when moving from Park into Reverse or Drive (I have automatic). ... I have been playing with the idle advance trying to get more ... I put in the remainder of the AT fluid I had on hand and the car never died on shifting after that.
starts but dies when shifted into drive or reverse - Suzuki Forum
1helpful
Car in park turn key starter engages engine starts and you can hear the Bendix still spinning in the ring gear put car into drive and then they stop spending
Does the starter engage again when you go back to park ?
Shifting from park to drive would cut the circuit from the key switch to the starter. The neutral safety switch prevents you from cranking the engine in drive or reverse.
I would say the key switch is not turning off power to the starter when you go from start to run.
Battery fully charged, engine won't start or even turn over, gear locked in park, brake pedal is depressed.
This may help: http://www.toyotanation.com/forum/274-2nd-generation-2004-2010/199861-04-sienna-transmission-lock.html
There are multiple issues here.Won't crank? Go direct to starter.
Possible recall:http://www.toyoheadquarters.com/threads/2004-2005-2007-2009-toyota-sienna-shift-lock-solenoid-recall-d0r.206/
2answers
What causes 1996 Dodge Neon SOHC automatic transmission to delay or slip shifts?
that is a hum dinger, largest ever posted, in one shot.
very good.!
one word , the transmission slips. (never drive a slipping tranny)
overheat indicator.! that is key.
many newer cars will change the transmission shifting any time
the engine over heats.
and overheat wins over transmission , every time.
if the engine burns up, what good is any transmission.? nada.
solve overheat first.
slip or flare.
is when the engine RPM rises fast and the car dont go faster.
SLIPS.
and slipping burns up trannyclutchs and increases the damage. inside the transmission, dont do that. dont allow it,
park it and fix it.
on some tranny there is a temperature sensor that the TCM
watches and changes shift patterns based on AFT fluid temps.
and if the ATF fluid gets too hot , it takes actions. to keep the tranny from harm.
why not get a scan too and see what DTC errors there are..
DTC, engine overheate.
DTC< tranny overheat (caused by above)
My engine starts, idles great but when in gear to go, it hesitates
Can be issue with transmission or its related components.Many car models face such problems.
For complete step by step troubleshooting,few help links are provided below.Click the link below and go through its procedure to resolve the problem:----
Engine misses and truck jumps? Hard to down shift? Issue with high gear only? http://technoanswers.blogspot.in/2012/02/engine-miss-and-truck-jumps-hard-to.html
Car sitting for year, now will not crank and go in gear? http://repairhelpcenter.blogspot.com/2012/01/car-sitting-for-yearnow-will-not-crank.html
2004 Peugoet: Clutch not going in gears?
http://whoisbyme.blogspot.in/2012/05/peugeot-307-clutch-will-no-go-in-gears.html
Engine stumbles and shuts off in forward gear on Toyota Land Cruiser? http://schematicsdiagram.blogspot.com/2012/01/engine-stumbles-and-shuts-off-in.html
Transmission problem? http://schematicsdiagram.blogspot.com/2012/01/transmission-problem.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Manual Transmission Clutch System Failures?
http://repairhelpcenter.blogspot.com/2011/11/manual-transmission-clutch-system.html
Automatic transmission will not go into high gear? http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Manual transmission very hard to shift from one gear to another? http://repairhelpcenter.blogspot.com/2012/01/manual-transmission-very-hard-to-shift.html
Dodge manual transmission will not go in reverse gear? http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
---------- 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
---------- Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
----------- Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
---------- Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
--------- Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
These details will help.Keep updated for more help.
Thanks.
1helpful
Shifter go stuck in park, 2001 s500
YOU WILL HAVE TO REPLACE THE STOP LAMP SWITCH OR THE COMPLETE GEAR SHIFT
ASSEMBLY.MOST LIKELY THE SHIFT ASSEMBLY.YOU MAY BE ABLE TO GET IT OUT OF PARK BY STRIKING DOWN ON THE SHIFT KNOB AND PULLING TOWARD REVERSE AT THE SAME TIME WITH THE IGNITION TURNED ON.IF THIS WORKS,PULL BACK TO NEUTRAL AND START ENGINE.THEN YOU CAN DRIVE IT TO REPAIR FACILITY INSTEAD OF PAYING A TOW BILL.IF THIS WORKS CONSIDER YOURSELF LUCKY AND TAKE ADVANTAGE OF IT NOW.IT WON'T CONTINUE.
3helpful
Car will not shift into gear
Sounds like a linkage/cable to me. Disconnect the linkage at the transmission and move the shift actuator by hand to see if there is the same things happening. Don't try to do this with the engine running unless someone is holding the brake inside the car.
SHIFTING PROBLEM '03 E320 WAGON
mercedes e320 wagon gear shifting problemgear start from 2,3,4,5, not from one
plz help me i change 2 gear so many computer still facing same problem
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
