Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Motor/Blade Control Assembly Switch is bad
I have a Homelite Cordless Mower (UT13122) and the other day it would not come on at all when I pulled the lever. I opened the switch assembly and it was melted on the hot side.
Any suggestions on where I can get a new Control Assemby?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
Dbk4456:
Thr the following web page: www.homelite.com
They have a page called "service and support" I'm sure you should be able to get a replacement from them. They also have a listing on area service centers.
Hope this helps Good Luck Loringh
PS Please leave a rating for me Thanks
Posted on Nov 12, 2008
Can't pull cord to start lawn mower
Either the motor is frozen or the start assembly is jammed.
Aug 12, 2017 | Garden
I have a Homelite 24v cordless lawn mower model UT13122 that doesn't run
im not exactly familiar with this model , but a few of these new fangled lawn mowers have come my way in the past , what I've found on most of them there susceptible to the same problems the power mower have , they have safety switches and hold handles that do malfunction , also they do have battery's and those are susceptible to bad dirty connections
Jan 20, 2017 | The Health & Beauty
Need Homelite Mower UT13122 wiring schematic to check switch problem. Battery fully charged
Check the switch for current flow with and without the key. Then make sure the ground switch is disengaging when you pull the handle.Possible stretched cable.
Dec 11, 2012 | Garden
I need to remove the blower motor from my Emerson Quiet Kool model 1350, how do I do this..
First open the control panel and remove all wires of your fan motor from the control switch and the capacitor. Remove also the compressor wires. Unscrew all panels and move the evaporator farther from the mounting base Pull-out the fan motor assembly with the panels. Unscrew the blower, fan blade, and them from the assembly. Unscrew the motor and now it is free.
Aug 31, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
When engaging the blade for my Husqvarna riding mower, nothing happens. I recently had the mandrel assembly replaced for the left blade, and this is the first time I've tried to start it up.
It's possible the repair folks didn't properly reinstall the mower deck belt. Check that it's in place, and under good tension. If that's OK, look at the wires to the mower engagement switch (PTO switch) and make sure the connections are on tight. Then check the motor pulley where the PTO clutch is, making sure those wires still in place.
Jun 10, 2010 | Husqvarna 165HP 42" Lawn Tractor
I need the battery wiring diagram for HomeLite UT13122. I took out the old batteries without documenting the wiring thinking it was in the manual.
Short blue cable goes between the negative and positive terminals on one side of the battery.
Thick white from cable that goes to the switch and thick wire that comes from negative terminal of motor go together with the small black wire from the hood - connect all 3 wires to the negative terminal on other side.
Thick green wire from cable that goes to the switch goes with the thin red wire from the hood - connect both wires to the remaining (unused) positive terminal.
Jun 10, 2010 | Electric Garden
Homelite ut13122 replace battery,need a wiering diagram
I have seen the wiring diagram and it does not make sense to me. I normally write a diagram of the wiring when i take the cover off to keep things straight.
Sep 30, 2009 | Homelite Garden
Cannot pull rope out to start mower
Bad news , Mower has sit up too long and the piston / crankshaft has become rusty and froze in place. (fix) buy some liquid wrench it comes in a can at your local hardware store...Tilt the mower onto its front wheels and remove the spark plug. Fill the Cylindar with the oil and leave it for a couple days. after a few days lean the mower back and attempt to pour out the left over oil. Then (Check Your Oil level) preferable replace old oil and pull choke..and start mower...if the engine is still frozen (Buy a New mower) 125bucks Sears.
Mar 22, 2009 | Mtd 22" Yard Machine Push Mower
Motor has low torque
common complains for electric & cordless mower is that they are not ment for cutting on wet or dump grasses or long tall grasses they will bog down. for this type of unit blade should be extremely sharp. also clean the under the deck so you can better air flow for the blade. if your switch & rectifier are new & in right connection then have you armature check for short circuit..
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
361 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
