Question about RCA F27440 27" TV
27'' RCA appears out of focus on the vertical Edges of the Screen
I have a 26" RCA Colortrack TV model # G26231TN manufactured in July 1989 that is slightly out of focus on the left and right edges but appears to be in focus in the centre area of the screen. I have electrical training and am hoping to be able to replace the part if you are able to identify it to me. Can you help me with this?
  • paul_lapierr Jan 21, 2009
    Thank you for trying. I junked the TV.
  • 3 Answers
I've seen this on many computer CRTs as they age past 6 years. I would imagine that the gun alignment is out. Are all the colors (RGB) fuzzy, or is it hard to tell?
1. Sometimes, extreme settings of contrast or color (usually to offset low output from aging CRT) can appear to unfocus your screen. Adjust color/contrast down if they are maxed out or close to highest setting/pot level.
2. A very likely culprit is unshielded speakers are too close to the screen. If this is the cause, the speakers' magnets distort the part of the screen closest to them (sides), and it will get better/worse as you move the speakers away/closer to the TV. If there are not magnets near the TV, and degauss function does not fix problem ('89 TVs have degauss?), see #3.
3. The focus can be set by adjusting the flyback transformer. As an experienced electrician, you should know about the dangers of messing with the insides of the unit.
If this fails, you might have other bigger issues. I'd suggest a nice trip to lead reclaimer if so. I'd say 19 years is quite a life for a CRT.
Posted on Jan 18, 2009
Vertical line on tv screen
This problem have been answered.
Aug 22, 2012 | RCA TruFlat 27F520T 27" TV
Thin white horizontal lines have appeared on the upper quater of the screen. Under these lines a greena red line has appeared. Bottom three quarters of screen is good.
u have to change a capacitor(470mfd or 100 mfd) in vertical section of u'r tv circuit board..if u r a tech person try this...
Jan 26, 2010 | RCA F27442 27" TV
Lost remote were to get code for 1988 colortrack
cant get input to work to play dvd menu wont come up with universal remote
Dec 23, 2008 | RCA 27V520T 27" TV
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
RCA tru flat 27 tv problem
the capacitor of vertical section is problem of your tv,so replace the capacitor value 100/50volts in or else all capacitors in vertical section.
Oct 14, 2008 | RCA TruFlat 27F520T 27" TV
Intermittent Defect on LCD TV
If new, you should not remove anything, just send back to store or Manufacturer
Mar 13, 2008 | Philips Magnavox 27MS343S 27" TV
Truflat 27 inch rca
vertical capacitors beside of vertical ic no other problem the capacitors only
Aug 15, 2007 | RCA TruFlat 27F520T 27" TV
RCA F27440 27" TV Logo
130 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
