Error code sc 818
Ricoh 2238 color
2 Suggested Answers
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Ricoh 1035 error sc 818
hi
this error happened when :
Incorrect Function DIMM installed in Slot #2 on Controller PCB. (Slot #2 is for PostScript Option only) so you can:
Reload System Firmware.
Replace Controller PCB
for fix that.
Oct 25, 2012 | Ricoh Aficio 1035 Copier
I need some solution for the error code for ricoh aficio 220,the error code was SC 543..can you help me for this problem..tnx..
Fusing overheat error
Symptom:
Detected fusing temperature
remained above 230°C for 1
second.
Possible Cause:
• Fusing thermistor defective
• PSU defective
Nov 22, 2010 | Ricoh Aficio C811DN-T1 - printer - color -...
I have this error code on my ricoh aficio cl7200 : SC 440-02
On the CL7200, sc440-02 is a color drum motor error. This error could be caused by a bad color drum unit (any of the 3 colors) or the drum gear positioning sensor, but more often than not it is because of a drum motor that went bad. There is one motor that controls all three color drums -- when this motor goes bad, you get the sc440-02 error.
Apr 23, 2010 | Ricoh Aficio CL2000N Laser Printer
RICOH 2238 C ERROR CODE SC680
SC 680 BCU/ MUSIC communication error After the engine CPU sends a message, the Music CPU does not respond within five seconds three consecutive times. • Toner cartridge memory chip loose connection • Memory chip problem • Memory chip cable wiring problem 1. Turn the main switch off and on. 2. Check if the toner cartridge is installed correctly. 3. Replace the toner cartridge. 4. Check if the harnesses are not damaged. 5. Replace the BCU.
Mar 12, 2010 | Ricoh Aficio Type 2238 (411603) Print...
Error code
SC 818 stands for controller error.Unplug the machine from the power outlet and plug it back in after couple minutes.If it is just a software error the printer should start working again.If you try it several times and error code keeps popping up, the controller board is defective and it needs to be replaced.
Oct 04, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Apr 24, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
531 people viewed this question
jasbo
jasbo
