Question about Uniden GMR325-2 (22 Channels) 2-Way Radio
Incredibly bad battery life
I have a set of GMR325 and new alkaline batteries run out in about an hour of standby. They die in a few days of the radios being OFF.
I received the radios as a gift or they would be going back to the store.
Suggestions?
  • 123 Answers
I think there is a problem send them back to store to replace under warranty
Posted on Nov 13, 2008
New battery charged and it only runs a few mins and stops, what causes this
a fully charged or a new alkaline battery should power a remote for several hours non stop, if your's discharges in minutes either the battery cell is suspect or the charger or there is an undue load on the output. Try a new non rechargeable alkaline battery, if this behaves in the same way you have a fault on the handset, especially if the battery becomes warm during its short period of use. You could "pop" the handset open and check for liquid ingress around the keypad which could cause continuous operation, but the life span would suggest a greater drain than I would expect from this type of cause.
Jan 19, 2016 | Sharp Aquos Televison & Video
Why are the batteries dying so quickly in my Kodak 12MP?
The main complaint against compact digital cameras used to be battery life. This was in the days when a 4 or 6MP would have been top-of-the-range.
The life of standard zinc-carbon batteries could be measured in minutes rather than hours and decent alkaline batteries might last the duration of a wedding but might not.
Manufacturers rushed to produce better batteries to meet the booming new market and the camera manufacturers began fitting rechargeable lithium batteries as standard in basic and lower cost cameras and with further developments in technology batteries now last much longer.
Leaving the batteries fitted into the camera when it wasn't being used didn't help much as the circuitry had to be kept alive to retain the settings.
Your camera might have a fault causing the batteries to discharge quickly but if it is working ok, probably not. If you have long experience with your camera and it has suddenly started costing lots of batteries it might be a good idea to update it. It has certainly been many years since Kodak cameras had the reputation for quality...
Meanwhile I suggest you use only high-capacity lithium batteries and remove them when the camera is not going to be used for a while.
Feb 28, 2015 | Kodak Cameras
The camera(Fujifilm Finepix AX 250) says that the life of brand new, never used LR6 AA Alkaline batteries is gone in 10 min-1hour, when the batteries have plenty of life left. The camera takes 2 AA LR6...
A search of the Fujifilm website provided no answers. Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol. Also, I would switch to 3 or 4 sets of rechargeable batteries. That way, you always have a fresh set ready and you'll save money in the long run.
Dec 15, 2010 | FUJIFILM AX250 Digital Camera
Brand New Canon Powershot A1000 IS battery power always low
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 22, 2009 | Canon Powershot A1000IS Digital Camera
Using up batteries in two days
if you are using "AA" size, do NOT use typical alkalines in your camera, they die too fast. Buy rechargable NiMH batteries and a charger at Walmart or somewhere. These will hold a charge longer for you. Also be sure to turn off teh camera when not shooting because the camera is always draining battery life when "on."
Apr 27, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
My vivacam kills batteries within a few minutes
Do not use alkaline batteries. Buy NiMH rechargables and keep a couple of sets on hand fully charges. ViviCam's eat alkalines alive!
Apr 25, 2009 | Vivitar ViviCam 5100 Digital Camera
Charging new battery
usually 8 hours.
for first charge.
on a brand new battery
Jan 29, 2009 | IBM ThinkPad T41 Notebook
Short Battery Charge
Hello Dave2794875,
According to manufacturer specifications the NiMH rechargeable batteries should provide about 12 hours of operating time assuming a 90/5/5 operating cycle (90% standby, 5% receive, and 5% transmit). Theoretically, decreasing the volume can help somewhat but should have a minimal effect.
If you are only seeing two hours of standby time then you are definitely not getting the specified amount of time. This could be indicative of a problem with the charger or the battery pack or both.
Using disposable alkaline AAA batteries, you should see an increase in operating time because alkaline batteries have more capacity and last longer then rechargeable batteries. However, if yu do a lot of operating the cost of disposable AAAs can add up fast. For most users the rechargeable batteries are much less expensive in the long run. If you only use the radio occasionally then alkaline batteries are the way to go.
Hope this helps,
Ken
"Go Ahead. Use Us."
Jul 26, 2008 | Uniden GMR-1558 / 2CK 2-Way Radio
Choosing batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Uniden GMR325-2 (22 Channels) 2-Way Radio Logo
145 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
