Question about Microwave Ovens
Smeg fme20ex microwave - bulb replacement!
Hi!
I have a smeg fme20ex microwave and need to replace the internal bulb. There is none visible in the unit and neither a part which can be unscrewed to expose the bulb.
Do i need to remove the unit from the fitted kitchen (will be a problem as it is sealed to the cupboards!)?
thanks
James
  • walpolec Dec 28, 2008
    Snap! Except my oven model number is FMC30X.
    Solution would be greatly appreciated.
    Thanks
  • 27 Answers
SOURCE: Siemens HF87950 Internal Bulb replacement
Move unit forward out from enclosure about 20cm....the light is covered by a small panel on top of the casing.(uses torx T20 screws) Remove lid and replace bulb!
Posted on Jun 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: damaged inner seal tape on whirlpool microwave door window
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 08, 2008
SOURCE: I need to buy a new MBBS Thermador Microwave
I spent the better part of three days trying to find a microwave that will fit and it's hard because so many are on line only. Last night I successfully installed the 2.2 cu. ft. GE profile counter top unit with inverter technology. The unit is an exact match, the Thermador even fits in the GE box with the styrofoam! I installed the venting materials for the side and rear vents and the platform at the bottom. I put the clips and decorative molding on and it's perfect! I found it in stock at Lowe's for $198. I took me about 45 minutes total to install. If I can do it, anyone can - 48 year old mom with 5 kids!
Posted on Dec 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Replace light bulb on Whirlpool GMC305PDS07
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
SOURCE: Maytag microwave light bulb MMV5207BA/BC
A 20W, 120V replacement xenon halogen bulb with G8 base can be purchased from Lowe's.
Posted on Apr 21, 2009
This is an over the stove microwave. Need help replacing the light bulbs on the bottom of the microwave.
Disconnect the power and get a flat bladed screw driver to remove some of the bulb base away from the socket. Insert long nose pliers into the area created and turn base counterclockwise to remove.
Nov 21, 2015 | Microwave Ovens
SMEG Microwave FME 20EX3 - light bulb has blown but unable to find where it is to replace it
my panasonic light went out and Panasonic support told me I had to take it to a service center to get it replaced - ARE U KIDDING ME!!!!
Well it required taking the cabinet totally off to get at it. Just watch where u put ur fingers. The big capacitor holds a charge for a long time.
Sep 14, 2015 | Smeg Microwave Ovens
I need to replace the light bulb on a 1993 Panasonic microwave model # NN6583A?
remove screws and pull it apart, find the bulb and replace it.(unplugged of course)
Sep 27, 2013 | Smeg FMC24 850 Watts Convection /...
THE BULB HAS STOPPED WORKING ON MY HINARI LIFESTYLE MX905CEGSS MICROWAVE. HOW DO I REPLACE THE BULB?
The bulb of most microwave ovens can only be accessed by removing the main cover.
This is usually a fairly simple procedure and requires only the loosening of a few screws which are situated on the side and/or back of the oven.
Once the cover is removed the bulb should be easily visible & usually consists of the ES or screw in type of connection.
Best wishes,
Graemevm
Mar 24, 2011 | Microwave Ovens
Bulbs UNDER the microwave burned out; new bulbs don't work
i know this is going to make no sense . but in my samsung service cd it is in BOLD PRINT YOU MUST DISCONECT POWER BEFORE REPLACEING BULBS , OR DAMAGE TO TIMER WILL RESULT ! the first time you changed them did you disconect power ? if not , your board might be toast , $$$$$$$$$
Jan 24, 2009 | Samsung SMH7174BC Microwave Oven
Microwave oven turns off
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
It may be worth getting it repaired. Shop around for prices and see if it is worth your while to repair it or simply buy a new one :)
Sep 29, 2008 | Microwave Ovens
Smeg Microwave Components
Generally speaking, light bulbs can be had from common sources such as department stores, home improvement stores, and hardware stores. Of course, I don't know much about what you'd call those places "down under and over a bit", but I'm sure the terms will translate well enough. *grin*
May 16, 2007 | Smeg S43KIT3750EB Microwave Oven
Replacing the door catch
If you're talking about a hook-like device that sticks out of the door and goes into a hole in the chassis of the microwave (or any other internal part of the door for that matter) you'll have to take the door apart. Brands and models vary, but some use screws which are obvious, and others use hidden hooks similar to the ones in the drawing I've added to this post. If you can post or e-mail photos of the area where the part goes, we may be able to translate our experience with other brands to yours.
Jan 30, 2007 | Smeg FME24X Microwave Oven
Microwave Ovens Logo
303 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
