Question about Oster 76076-010 Hair Trimmer
Where do you put the two little springs, and what do they do? My blades have started to rattle on clipper. Oster turbo clippers.
  • 4 Answers
The springs probably go with the carbon brushes, to hold them in. To find the brushes, use a dime to unscrew the two circles on the side of the clippers.
The rattling could be from loose screws on the blade hinge. My turbo clippers did the same thing. The blades rattle if the screws are even slightly loose.
Posted on Nov 13, 2008
The brand new gear lever on my oster a5 isnt moving the clipper blade
make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Jun 21, 2014 | Oster Turbo A5 2-speed Dog Pet Clipper...
Oster clippers
it could be metal fatigue from the blade. Try a different blade and see if it does the same. If it is still rattling it could be your blade drive needs to be replaced. Sometimes the screws that hold the blade drive in place come lose or striped so you may need to check them.
Apr 23, 2013 | Oster Turbo A5 Two Speed Clipper - Blue
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
Oster Golden A5 Clippers will not cut
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Aug 23, 2009 | Oster Golden A5 1-Speed Universal Motor...
Can get it right
Jun 11, 2009 | Oster Golden A5 2-Speed Universal Motor...
A rattle problem with my Oster Golden A5 Clipper!
The screws on the side of the housing don't serve any purpose other than keeping the brush and spring in the clipper. You can send your blade in for realignment or call 800-830-3678(factory service) and they will help you with all your issues.
Apr 13, 2009 | Oster Golden A5 2-Speed Universal Motor...
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
Apr 08, 2008 | Oster 76076-040 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
439 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
