Question about Nikon D80 Digital Camera with 18-135mm Lens
D80 shutter is stuck
The shutter on my D80 is stuck in the open position. Battery removel, resetl button and rotating through settings and f stops has not worked.
  • 1 more comment
  • ejaffe5652 Nov 28, 2008
    The shutter will not release most of the time. When it does, and it is a daylight picture, it is very overexposed. I have tried this in many shooting modes.
  • Anonymous Apr 01, 2009
    in the viewfinder all you see is black, i think the shutter dorrs in the camera got stuck. i read the manual to do the mirror lock however, i didnt see that option in the menu. i have the d80
  • Anonymous Mar 23, 2014
    turn the on button shutter stuck
Followed the mirror lock procedure as outlined in the manual for cleaning the sensor. That solved the problem.
Posted on Nov 13, 2008
Where is the aperture ring on d80 Nikon
If you are using an older lens the aperture ring will be close to the camera body when the lens is on the camera. In order to set the aperture with a D80 and older lens you must set the aperture ring to "22" or the highest number on the aperture ring available. For newer lenses there is no aperture ring. You set the aperture by setting the dial on the top left of the D80 to "A" for Aperture Priority. You then set the aperture by rotating the front dial on the right side of the camera under the shutter release button. On older lenses, after setting the aperture ring to the highest number, you then set the aperture in the same manner.
Sep 22, 2014 | Nikon D80 Digital Camera with 18-135mm...
'err' sign on display nikkon D80, and appear r 15 when shutter button is press
"rXX" is just the camera estimate of how many pictures left on memory card. As for "ERR": while camera is in "On" position, take out battery and hold shutter button approximately 30 seconds. Turn camera "off, replace battery and turn "On" again. If thre is a hardware reset button (check manual carefully) while camera is "On" use that reset button/
Feb 19, 2011 | Nikon D80 Digital Camera with 18-135mm...
Sometimes there is a 6-10 second delay in the shutter also there are times the shutter wont work at all. What does r11 and r9 mean when depressing the shutter button half way down?
"R(x)" or "R(xx) is the estimated numbeer of shots left on your storage card. For the delay: with camera in the "ON" position, remove battery(ies), and while waiting approximately 30 seconds, continue holding the power button. REplace batteries and see if that helps. Also, if your model has a hardware reset button, give that a go.
Dec 10, 2010 | Nikon D80 Digital Camera with 18-55mm Lens
Shutter not responding!
i had a similar problem - it was the interface between the lens and camera - some of the connectors were stuck depressed, i just poked them and they popped back out.
May 05, 2009 | Nikon D80 Digital Camera
Shutter stuck half open
This sounds like the mechanism has worn. It is a straight forward service centre procedure, I wouldn't recommend trying to do anything that will make it worse. Leave it to Nikons engineers.
Mar 11, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Shutter won't release
If the lighting is low and shutter speed is set for a long period of time its the function of the camera taking the picture. If it is a malfunction of the shutter take it in for cleaning you might have foriegn material stuck in your shutter mechanism
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80, setting not remembered
I'm thinking it's an internal problem - probably needs fixing at Nikon. I can't think what else you can do.
Sep 23, 2008 | Nikon D80 Digital Camera with 18-135mm...
D80 shutter issue
contactjoni,
Your shutter will stick if it gets dirty or dust gets in the camera, a reputable camera shop can inspect the shutter, the sensor for dust & dirt and can clean it for you. If the battery is low while shooting the shutter can also stick on longer exposures.
randy320sgi
Jun 28, 2008 | Nikon D80 Digital Camera with 18-200mm...
NIKON D80
check that your flash is not up. Or if you have an external flash, turn it off.
Jun 16, 2008 | Nikon D80 Digital Camera with 18-135mm...
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
Nikon D80 Digital Camera with 18-135mm Lens Logo
1,031 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
