Question about White Sewing 1740 Mechanical Sewing Machine
Sew easy sewing machine breaks thread
The only name that shows up the sewing machine is sew easy appliances corp of America. It was my mother in laws who has pasted on and I have no clue to where the users manual is. So this is my problem I thread the machine like I'm suppose, bobbin works fine, I start to sew and after the third stitch the thread breaks. The needle is not hitting on anything that I can tell, the thread is new, I have tried setting it on every tension setting there is and it still breaks. The needle is brand new its inserted properly. So is there anyway you think you can help me out.
Thank you so much,
Jamie Jarrard
I have tried everything and the thread still breaks after the first stitch. I thought it might be the need placement, It is an old white machine with no manual. I have the needle set up to thread from the side. Is this correct.
Posted on Nov 02, 2009
    Problem Solver:
  • 23 Answers
The machine is not threaded correctly, also use medium weight fabric. Check the size of needle. Try a size 14. The bobbin tension may be to tight. If nothing works take it to an expert. After he fixes it make sure he shows you how to thread it.
Posted on Nov 19, 2008
The upper thread tension keeps breaking the thread, no matter how low I set the tension. How do I fix it?
Not a technician, but I had same issue not long ago, it was old dried out thread. Once I replaced with new thread, no more issues. Something easy to try. Also might want to double check to make sure no thread is between the pressure plates. I use canned air to spray them out once in a while between annual cleaning.
Apr 21, 2016 | Singer 8770 Curvy 225-stitch Computerized...
How do I fix top tread breakage on a white model 935
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Jul 27, 2013 | Sewing Machines
White model 935 maintenance help
Jul 27, 2013 | White Sewing 935 Mechanical Sewing Machine
Kenmore sewing machine jams and breaks the needle
always make sure the needle is inserted correctly and all the way
up into the needle holder
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin case is inserted correctly in to the machine
if it's a front or side loading bobbin case
make sure the top thread has not come off the top thread take up
lever
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 01, 2012 | Kenmore Sewing Machines
Need a free manual/instructions Kenmore sewing machine #158.10691
Need a manuel for a Kenmore sewing machine model 158.10691
Sep 30, 2009 | Kenmore Sewing Machines
I have inherited an old 'Brother' sewing machine with no manual
i have an old brother machine maybe back in the 60s-80s and the thread keeps coming out of the needle and i dont know how to do anything with the bobbin.i have no idea how to use the machine at all.i would love to learn any help.cant find any thing online to help.
Jul 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
How do you thread a SInger Sewing machine 2623
hi! there,
you can show some actual bobbins winder and threading go to internet explorer and type the address of "www.youtube.com" then on search type "sewing machine".there is a slide show for sewing instruction.just click the slot and it play the video showing what you want.regards don' t forget to rate me.
Apr 09, 2009 | Sewing Machines
SINGER CE-150
reduce the upper tension until the thread doesn't show on top anymore. This will probably solve both problems.The problem you describe is mechanical not computer related.
sewman7
May 19, 2008 | Singer CE-100 Futura Computerized Sewing...
White Sewing 1740 Mechanical Sewing Machine Logo
181 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
