Question about Dell Dimension 8200 PC Desktop
Dell Dimension 8200 won't power up
Several months ago I replaced my old Dell Dimension 8200, transferred all the data to my new computer, and put the old Dell on a shelf. I now would like to use the 8200 again, but can't get it to power up -- no lights, no fan, no nothing. Power source is fine. I never had any problem with it before. It hasn't been dropped or otherwise damaged or abused; the only thing that's happened since we last used it is several months of being inactive and unplugged. Any suggestions?
  • whozis Nov 27, 2008
    I have a Dell Dimension 8200 that made a loud screeching noise, screen froze, could not turn it off. I pulled the power plug. I reconnected it, now it will not start. No lights on front panel. Green light on motherboard. No fans. I replaced the power supply, but the same thing.
    Any ideas how to troubleshoot it?
  • skellyelly Jan 13, 2009
    I have the same problem at work. I went through all the troubleshooting on the internet and even talked with the Dell tech support. They had me unplug the power supply 4-pins for the hard drive, floppy & optical drive - the computer would power on! I switched the 4-pin connector (ied?) to the hard drive and the computer turned on again! I then powered off, shut the case and tried to turn the tower on - no luck. The techie thinks that there is a problem with the motherboard or the ied pin/connectors?? I am suppose to take it in to radio shack?
  • 4 Answers
I have 2 dell dimension computers 4600 and 8300 and having worked with dell for 4 years or so i found that if you get the no power problem all i ever done was to reset the power supply by moving the red switch 120/240 volt at the rear over and back a couple of times making sure to set it back to where it was originaly .you may have ot breal the seal that covers the switch. works for me each time and fires up the computer straight off.
Posted on Feb 05, 2009
  • Dell Master
  • 998 Answers
If the power button does not light up at all, I would guess the power supply has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 12, 2008
Dell eDimension 8200 computer has started but monitor scren remains black
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Sep 10, 2012 | Dell Dimension 8200 PC Desktop
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Will This Hard Drive Work In My Dell 8200?
Yes it will work. You probably will have to use the CD that came with the drive to make sure the HD is recognized.
Jul 13, 2008 | Dell Dimension 8200 PC Desktop
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
May 14, 2008 | Computers & Internet
CPU fan died again
what's the output at the mobo connector?
Mar 02, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
1,122 people viewed this question
Alun Cox
