I accidentally set "Parental Control" in the Menu and exited. Now I only get one channel and I'm unable to access the Menu or any other function. The TV only turns ON/OFF and I can adjust the volume. Note: I do not have the remote to this TV.
-   TV is locked on channel 3 and the remote is lost.-   pennyhazelto
Apr 27, 2008
-   Can not locate a remote for this television. Is there anyway to unlock parental controls without a remote. I also need to find a way to program channel 3 because when we scan through channels # 3 does not get programmed.I think I need to do it manually instead of scan through. -   Guest
for an unknown passwrod try, go to parental control in menu then push mute,pisplay,clear,reset buttons in sequence. you may need to borrow a friends remote to do this. once in you can change your setting. good luck
There is no channel search or add delete channels, even when you push in the channel number it wont...
(More)
There is no channel search or add delete channels, even when you push in the channel number it wont go.
