Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Convergence i have a Sony Kp-46wt510 that is about 2 years old. It has been working fine until about a week ago. When we turned it on in the morning, after it was off all night. all three colors where out of convergence. I tried flash focus with no results. When I go into the manual convergence mode the screen comes up but I am unable to move the colors. I know just enough about electronics to be dangerous, but if pointed in the right direction could possibly fix. Any suggestion would be greatly appreciated.
    President:
  • 3,130 Answers
You need to go to http://www.partstore.com, enter your model number,look up under that model number STK #(@-560. Order Two of the part number 874901908. These also need heat sink grease in the back of these ICs when they are replaced. If you know how to solder, then good luck, and please be carefull!.. Please do not forget to rate this thread.
Posted on Nov 27, 2006
  • Larry  Dillon
    Larry Dillon Nov 27, 2006
    oops, the IC numbers are STK392-560 sorry
SOURCE:
I have a Sony KP-65WS500 from 10/2002. There are thin red arcing lines across the screen when the scene is dark or black.
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 16, 2010 | Sony KP-65WS500 65" Rear Projection...
I have a Sony KP-53HS10 TV for over 9 years. It still works great, good picture. But few weeks ago, it started making a "ssssssi" noise after turning on 4~5 minutes. The noise might come from a cooling fan...
There are no fan in this tv.This tv most common problems are the dead convergence board parts have problems,picture have colors lines R,B,G out of alignment,have colors shadows,and 3D pictures.The convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergence problems.The problems u discribing,it a starting point,just the convergence problems,have not take it effect yet.Sooner or later ur tv will have the convergence problems.
Jun 23, 2010 | Sony KP-53HS10 TV
Sony KP-65WS500 Rear Projection TV About a week ago the left side of the screen started to a slight blue halo over faces, hands, and some of the white letters were light yellow. I adjusted the convergence...
Thats a convergence failure issue. The Sony Type 1 convergence repair kit available from www.tvrepairworld.com is the kit your model uses. The kit contains the parts and the CD with instructions.
Dec 20, 2009 | Sony KP-65WS500 65" Rear Projection...
Whole Screen Turns Blue in seconds....
This could be a problem with the Blue CRT it archs or overdrives intermittently. I would have a technician test the set and give you an estimate - if it's the CRT it's usually not worth repair- but it could be video or a screen voltage related problem. It's worth the estimate.
Oct 31, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Sony KP-46wt510 Convergence issue
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Oct 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-51WS510
Your tv has a convergence board problem. Two convergence IC's need to be replaced.
Jul 22, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-43T70 green ghost problem
The cause of the problem can be that the CRT-s are getting weak. Life span of CRT is around 30000 hours of working time. Please calculate. If you need more info please advice.
Apr 03, 2007 | Sony KP-43T70 43" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
158 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
