Question about Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
Front cover won't stay closed
I have had the machine put away a long time . All I want to do is send not recieve. The cover will not stay closed. I can hold it closed. Does the green button on my right side help me... or can I get the handy silver tape to keep it closed. "Please wait " appears when I hold it shut, and it "Hums".. Thanks Renee
  • Anonymous Jan 06, 2009
    i have the same problem... screen displayed, out of paper and check cover. already followed the direction but not repaired. same display appear... out of paper, check cover. any suggestion?
  • retiredlady0 Feb 11, 2009
    My copier will no longer print. The lid pops up if it ever closes and then the paper pleats and does not come out. Sometimes the film sticks to the paper too and comes out with the copy. I have used alcohol to clean the rollers, etc. but it still does not work. Any hints?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
There is a sensor .i think it is dirty having dust onit .just open back cover find sensor and clean it properly.it will bi closed.MIAN AKHLAQ
Posted on Jan 04, 2009
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Brother mfc-7460dn toner replace toner will not go away
Remove drum/cartridge, close front cover, Menu, 1. General, 8. Replace toner.
Replace drum/cartridge. Close front cover.
May 07, 2012 | Brother MFC-7460DN
Where is the oil sending valve located at?
OIL SENDING UNIT MOST TIME LOCATED CLOSE TO OIL FILTER ON LOWER SIDE OF ENGINE BLOCK.IF OIL PUMP ON FRONT TIMING COVER OF ENGINE LOOK ON FRONT TIMING COVER OR ON THE FRONT SIDES OF THE ENGINE BLOCK.
Nov 27, 2010 | 1987 Dodge Ram 50
Jammed paper
There are 3 places to check for jammed paper.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
Error message should go away.
Apr 06, 2010 | Brother IntelliFax-2820 Laser Fax
Can't send faxes , keeps saying document jamed
Open the front cover by pulling it towards you (that is the cover where are the digits and other function keys), see if any paper has inside and than close the front cover and press the " Stop " button.
Remember if you do not close the front cover good the message will still appear on the screen because the machine thinks that the cover is not closed. That happen because of the sensor on the front cover which detects do the front cover is closed so check dose the door is good closed. If your machine do not pull the documents in the " document feeder " than open the front cover and you will see pair of rubbers inside, clean them with alcohol or glass cleaner and clean peace of cloth.
Jul 03, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
My mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Dec 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
All lights flashing
Try opening the font cover, press the GO button six times and then close the front cover.
Aug 09, 2008 | Brother HL 5250DN Laser Printer
Recipient recieves a black page
I have seen the print cartridge not being seeted cause this problem.
  1. Open the front cover by pulling the cover release buttons toward you, and raising the cover.
    Slightly lift up on the Laser Printer Cartridge and then pull it toward you, but do not remove it.
    WARNING: The Fuser is hot! Use caution when you are working in this area. To prevent damage to the cartridge, do not expose it to light for more than a few minute.
    CAUTION: Do not touch the green Photoreceptor Drum. Scratches or smudges on the Photoreceptor will result in poor copy quality and may shorten the life of the cartridge.
  2. Slide the cartridge back down along the slots until it clicks into place.
  3. Close the Front Cover.
    Then Unplug an replug in the machine.
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax Logo
55 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
