Question about HP Photosmart R827 Digital Camera
The view finder is blac
I charged the battery and turned on the camera the view finder is black I can't see anything.
I have a hp photosmart R827
    Champion:
  • 225 Answers
I would guess your shutter is stuck closed, or the lens digitizer is faulty. Either problem will result in replacing your whole camera lens assembly. Sorry.
Posted on Nov 13, 2008
HP Photosmart R725 card is unreadable just put in new SD card HELP!
Are you sure it's an SD card? The R725 works with SD cards 2GB or smaller. It will not work with higher-capacity SDHC cards.
Jun 09, 2014 | HP Photosmart R827 Digital Camera
Off lens,view finder is not workink
The view finder is the little window on the top left of the camera. If you want to use the display as a view finder, you have to press the button with the camera logo. It is called the life view mode. you use the same button to switch off the display. Be aware using the display, will drain the batteries quicker. Somewhat faster then with modern cameras.
see page 19 of the manual.
Dec 02, 2013 | HP Photosmart M307 Digital Camera
I have HP Photosmart R827 with the same problem. when I was uploading stuff onto my memory card I might have hotlinked and when I disconnected it said "Card Unreadable" and told me to format. i...
memory cards can become damaged. this can be from removing it at the wrong time or a file become corrupted, it can wipe the format off the card. and will need reformatting. dont do this on the camera as it can put the wrong format on the card. doe this on a pc, it will probably say when you instal the sd that it needs formatting. click yes, a box will appear and have it all set out for you but don't click format yet, in the box where it says restore device defaults click this. and then press to format. this will put it as the best for any device its being used for. if you had anything on the sd card before it will not be there before or after the format. hope this helps.
Jul 01, 2017 | HP Photosmart R827 Digital Camera
Camera completely frozen. Lens protector open. Won' start with battery or AC power. Performed hard reste, no change.
have you tried removing battery and putting it back in? also what does "frozen" mean specifically? is it frozen in the menu with buttons not working or not powering up at all?
Aug 03, 2010 | HP Photosmart R827 Digital Camera
HP Camera won't flash
HP wont get your money for another camera period- the have dropped cameras from their line up- in the UK any way.
The precise reason for the non function of the flash is not immediately fathomable - but it is likely non use ,the capacitor that triggers the flash in a full state and not having been discharged could have 'killed' it.
As with pretty well all low end digital camera s'repair' is not an option, only replace.
So off you go and buy a new one- if it is flash you need- but perhaps you can live without it.
So often you see folk using their camera swith the flash popping off when in fact non was needed.
Jan 27, 2009 | HP Photosmart R827 Digital Camera
Blurry view finder
this may occuer if you are trying to expose the camera to sudden temperature changes/differences.
Eg: From your Air Conditioned Bed Room to Day Light Under Sun Light
Sep 23, 2008 | HP Photosmart 945 Digital Camera
HP Photosmart R827 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
