Question about Zanussi TC7102W Electric Dryer
Zanussi TCE7127W - Exhaust air is damp?
Exhaust air is damp, producing condensation in the room- it is 2 years old and never had this problem before?
  • gboulton Nov 13, 2008
    Sorry, but should of added that its a condensing tumble dryer, the condensing unit has been cleaned and the door seals.- but still produces damp air?
    Scholar:
  • 66 Answers
Check the exhaust hose for blockage. They normaly need to be cleaned out periodicly
.The exhaust hose is how it gets rid of moisture.
Posted on Nov 12, 2008
How do you clean the filter
In order to look up the filter change procedure I would need the specific model number. However, filter changes or washing should be done regularly. Look for a very simple lift-out design that is washable in the kitchen or laundry sink. Soak in soapy water and rinse with spray nozzle.
As for the symptom "Blows out warm air" this is expected. The dehumidifier is less than 100% efficient, meaning that the energy that is used produces heat in the exhaust air. A 100% efficient design would still send all the heat energy of condensation (endothermic phase change) into the exhaust air. You should expect 1072 BTU per pint (1 pound of water). This is far more than the heat of crystallization (144 BTU per pound of ice) and therefore much more sensible when you feel the discharge air from the dehumidifier. Dehumidifiers typically operate in basements to both warm and dry the area where a sump pump may be operating to remove the water that seeps through the foundation. A dehumidifier is not a good idea for warm areas of the house. This will decrease the efficiency by increasing the temperature differential needed to get the evaporator coil below the dew point to cause condensation. The condenser coil will be much hotter than expected if the unit is operated in a warm humid room. Only air conditioners which discharge condensate and exhaust air to the outside of the structure should be used to cool a room.
Jul 06, 2014 | GE 50-Pint Dehumidifier
Ac exhaust fan
Yes for dehumidifier, no for heat mode. In dehumidifier mode all the unit does is takes air in, runs it through the evaporator (cold) coil and the back through the condenser (warm) coil discharging dry, slightly warmer air back into the room. In heating mode however if you don't vent the exhaust there will be no heat produced. Warm air will come out the top but cold air will also come out the exhaust (essentially, in heating mode all it does is operates as an air conditioner in reverse. Hope this helps.
Jan 11, 2014 | Whirlpool ACP102PS Portable Air...
NOT DRYING PROPERLY CLOTHES STILL WET AFTER 70MIN DRYING TIME CLOTHES ARE WARM DAMP
First check that the exhaust duct is clean, has no kinks and that the air flow is unrestricted. Sometimes water will condense inside the exhaust hose and not allow the damp air to flow.
I assume that the dryer works quietly, if not, then probably the blower fan needs replacing.
Feb 20, 2011 | Amana Dryers
Dryer is working but not producing any heat?
depending how old the dryer is and the usage three things to check
1st check the vent and exhaust hose for clogging of dust 2nd check your lint tray and the port for the exhaust 3rd a little more technical check the wires connected to the thermostat in case the dryer has shaken from and unbalanced load following that after unplugging it plug it in and try with a damp face cloth
if it doesn't work after these quick fixes call a service rep and before any electrical checks be sure to check your waranty good luck !
Sep 26, 2010 | Zanussi TC7102W Electric Dryer
Dryer is still getting warm, But clothes are coming out damp, not wet as such but damp. Could it be a blocked air filter? Dryer is five year's old however. With possibly above average use.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 08, 2010 | Zanussi Dryers
Fujitsu heatpump 13 years old is not heating room as it used to.filters are clean.i have gauges and would like to know what pressures are good and what pressures indicate low refrigerant or worn...
The refrigerant and compressor are related in cooling the room.As for heating problem the thermostat needs to be checked.
if you're used to a certain temperature of air and your heat pump is producing much cooler air, take the following steps. (Note that a heat pump may go into a defrost mode to prevent icing. When this happens, it can temporarily output cold air. Also be aware that the heat pump will have to work harder to produce heat.)
1) First be sure the thermostat is set properly. Try raising the set temperature 5 degrees F. and waiting a few minutes.
2) Be sure the room-heating registers are open.
3) Check the heat pump filter. If it's dirty, change it.
4) Be sure the auxiliary heating elements are working .
5) Clean the coils of the outdoor condensing unit.
If still the same problem then thermostat needs to be checked and replaced.
Thanks.
Jun 15, 2010 | Heating & Cooling
How to use my condenser dryer zanussi zdc 47100. do i fill the bottom bit with water or leave it empty ? just bought it second hand but has no manual !!
this is a drier ? and therefor no water is needed however you will need to ventilate to outside via the conveluted white hose that fits to the machine to prevent the damp exhaled heat fro machine condensing in the room dryer is positioned
Nov 27, 2009 | Zanussi Dryers
No hot air is being produced from my Zanussi TC 180 condenser dry
what make is it?is it a top lint screen or inside?
Mar 31, 2009 | Dryers
Zannusi TCE7127W Not turning if load too heavy
It is very likely to be the condensur,or it is called a capacitor ,device for storing electric charge to boost the starting of the motor under load.in other words change it.UF will be wrote on it maybe 10 uf .I feel wasted on this site its so easy .
Nov 30, 2008 | Zanussi TC7102W Electric Dryer
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Zanussi TC7102W Electric Dryer Logo
160 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
