Question about Toshiba (K000002020) Motherboard
Needing help with the bios
Can you give me a default password so i can reset my bios on a toshiba satellite
    Problem Solver:
  • 17 Answers
Please describe the error.
my best advice is just don't, insure your computer and make a claim.
I was working on computers back in 386 days and unless you know exactly what you are doing with a laptop - teers and grief - get a profesional.
If it is a BIOS error please send a discription.
Regards Alistar
Posted on Nov 12, 2008
How to remove bios password on toshiba satellite 1400?
Easiest way to do it is to just remove the CMOS battery and put cmos jumper on clear. That will remove the password and restore all of the default settings.
Mar 31, 2014 | Computers & Internet
Entered built in HDD1 user password
Hello
as the bios was reset the harddrive password was removed from the bios memory.
To get the password unlocked you will need to remove the harddrive from the laptop, buy a adapter so you can connect it to your pc and then do a few things Il tell you about later if your going to do it.
otherwice you can take the harddrive to a shop to be unlocked / reset to defaults.
May 10, 2008 | Iwill P4ES Motherboard
Sattilite l500 bios reset
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
May 03, 2012 | Toshiba Satellite (K000004080) Motherboard
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
Toshiba satellite pro sp2100 -> Mod No: ps210E
TOSHIBA
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 15, 2011 | Toshiba Computers & Internet
Some one put a password on the bios of my laptop toshiba satellite p305 s8900 how do i access the bios batery to reset it.
press either delete or f2 during the boot process to enter the BIOS you can reset or remove from there (be careful)
Aug 17, 2010 | Computers & Internet
CAN`T FIND THE RESET FROM THE MOTHER BOARD OF TOSHIBA LOPTOP MODEL dynabook satellite 2510CDT
Most _desktop_ computers have a small "reset BIOS" jumper.
Most _laptop_ computers do *NOT* have that jumper; if there was one, a thief who stole your laptop could delete any BIOS-password, and then use your computer. So, to protect you, the registered owner, there is no jumper.
Jul 20, 2010 | Toshiba Computers & Internet
I have a HP G6000 lap top & need a bios password / reset?
google for remove bios paswoord
Resetting the BIOS Password using Software Every system must store the BIOS password information somewhere. If you are able to access the machine after it has been booted successfully, you may be able to view the BIOS password. You must know the memory address where the BIOS password is stored, and the format in which the BIOS password is stored. Or, you must have a program that knows these things.
You can write your own program to read the BIOS password from the CMOS memory on a PC by writing the address of the byte of CMOS memory that you wish to read in port 0x370, and then reading the contents of port 0x371.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
  • ACER/IBM BIOS
  • AMI BIOS
  • AMI WinBIOS 2.5
  • Award 4.5x/4.6x/6.0
  • Compaq (1992)
  • Compaq (New version)
  • IBM (PS/2, Activa, Thinkpad)
  • Packard Bell
  • Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
  • Phoenix 4 release 6 (User)
  • Gateway Solo - Phoenix 4.0 release 6
  • Toshiba
  • Zenith AMI
Oct 26, 2009 | Acer (ACERMOTHERBOARD)
Sir my toshiba laptop is under bioword and i donnot know password .sir, listen how to open motherbroad satille a205-s5861 thank u sir
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
Jul 29, 2009 | Computers & Internet
My toshiba satelitte has for some reason has started to ask for a bios password. How can I reset ir?
  • Using a Backdoor BIOS Password
  • Resetting the BIOS Password using Software
  • Resetting the BIOS Password using Hardware
  • Vendor Specific Solutions for resetting the BIOS Password
Toshiba's backdoor password is TOSHIBA
Jan 04, 2009 | Computers & Internet
Toshiba (K000002020) Motherboard Logo
167 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
