Question about Nokia N95 Cellular Phone
Backlight on the screen not working
The Backlight on the keypad is working but not on the screen.(i cannot see a thing).The phone is working as normal and when i hold it up to light i can see what im doing but without the backlight it is nearly impossible to use. It is a Nokia N95
  • 1 more comment
  • Anonymous Nov 25, 2008
    I have changed my screen with a new one, and changed the sensor ribon and i'm still having the same problem
  • Anonymous Dec 13, 2008
    I have had the same problem with the screen, don't bother buying a new screen it doesn't work you'll just be throwing your money away if any one does know how to fix this please let us know
  • Anonymous Feb 02, 2009
    i too have the same problem but mine is a nokia 5610.
There is dim light on the screne
Posted on Dec 07, 2008
  • 101 Answers
Hi. The lights for the keypad are separate from the backlight for the LCD screen. The backlight for the LCD screen is actually in the screen itself so you need a new one. We sell them here http://www.formymobile.co.uk/proddetail.php?prod=n95lcd
Posted on Nov 13, 2008
I have had the lcd changed also the ribbon and mine still does not work,i have been told it cannot be fixed?
Posted on Nov 19, 2008
KEY PAD NOT LIGHTED
On candybar style push-button phone units, this indicates non-working or failed LED backlights.
Some phone models will have an option to turn off the backlight for both screen and keypad. This will normally be in the Settings Menu of your unit, and sometimes found in the user manual.
Hope this helps.
Nov 05, 2013 | Cell Phones
Nokia 6300 problems-frozen screen
i think u just format u cell & memory stick
Jul 24, 2009 | Nokia 6300 Cellular Phone
Cant change my sanyo 6650 mobiles incoming msg font
here i hope this helps you Display Settings
Changing the Text Greeting
The text greeting can be up to 15 characters and is displayed
on your phone’s screen in standby mode. You may choose to
keep the phone’s default greeting (“Sprint”), or you may enter
your own custom greeting.
To display or change your greeting:
1. Select > Settings > Display > Greeting > Custom.
2. Enter a custom greeting using your keypad and press .
(See “Entering Text”on page 39.) (To erase the existing
greeting one character at a time, press .
To erase the entire greeting, press and hold .)
Changing the BacklightTime Length
The backlight setting lets you select how long the display
screen and keypad remain backlit after any keypress is made.
To change the Main LCD or Sub LCD backlight setting:
1. Select > Settings > Display > Backlight.
2. Select Main LCDor Sub LCD.
3. Select Always On, Dim Only, or a preset length of time.
To change the Keypad backlight setting:
1. Select >Settings>Display>Backlight>Key.
2. Select Always Off or a preset length of time.
Note: Long backlight settings affect the battery’s talk and standby
times.
Note: The Always On setting returns to the previous value the next
time you turn on the phone.
Your Phone’s
Please rate this solution thanks...
Jan 30, 2009 | Sanyo Katana II (SCP-6650) Cellular Phone
K800i no backlight or keypad light. it is not a firmware fault a i took it to a specialist and they tried flashing it but no luck, they told m it needs a new screen but if that is the case why doesnt the...
go to setting and hit on display and u shold see when u get there then look for backlight and keypad light hit on them and u will be able to do the rest its easy
Sep 12, 2008 | Cell Phones
Motorola RAZR V3x Whiye screen problem
I have managed to fix the problem by doing a software update.
I stumbled across the solution..........I had the phone connected to the computer when I started it in the 'boot loader' screen as opposed to just turning it on. This time the computer recognised the phone was connected and through the motorola software update program I was able to update the software and the phone now works fine.
BTW I did lose all my address book, messages etc.
To start in the boot loader screen hold down the * + # + pwr keys all at once.
Jul 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
cHiPz.
Mar 17, 2008 | Motorola Mobility RAZR V3
Keypad backlight function turns off when call is connected
Plain and simple there is something wrong with the LCD on your phone, needs to be repaired if possible
Mar 13, 2008 | Samsung SCH-u740 Cellular Phone
Back light intermittant
You probably have a defective flex cable... comes with the lcd screen....
Jan 17, 2008 | Motorola Mobility i530 Cellular Phone
Nokia N95 Cellular Phone Logo
1,650 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
