Question about Nextel i860
Both of my interior and exterior screen don't work..
My friend changed the full cover on my phone and now the screen does not work...when i opened the phone, one of the wires where broken.. is their any way that i can fix this problem??
    Problem Solver:
  • 5 Answers
You can buy a new flip > or change the flex cable * I would suggest get a new flip. www.cdphonehome.com Nextel Repair Parts For Most Nextel Models.
Posted on Jul 25, 2007
Only the headlights work no exterior or interior. the lights come on when you open the door.
More than likely a bad headlight switch. check the fuses first, spray some WD40 into the switch second, and third; replace the headlight switch.
Jul 26, 2014 | 2004 Pontiac Grand Am
Door won't open
You must have popped the door rod off.
Mar 03, 2018 | 1996 Chevrolet Suburban
I have a Motorola Razr V3. Very recently the exterior and main screen went black. The phone itself still works (I can still call people and receive calls) but I can not see anything on the screens. Do you...
The reason your phone interior and exterior screen went black is because there is a problem with the flex of the phone.
The flex is the mechanism like a ribbon that connects the screen to the panel of the phone.
All you have to do is to replace the flex of the phone.
To replace it on your own, the process to do this are as following;
  1. Get the appropriate screwdriver (Torx 5 screwdriver).
  2. Remove the four rubber stoppers surrounding the screen to reveal four screws. Remove these screws.
  3. You can now remove the front cover. To do this, use a credit card to lever the cover up. The cover clips on and the levering motion will unclip it. Start at the top, then unclip the cover at the bottom, then both sides.
  4. Now detach the camera from the phone. Simply pull the ribbon away from the phone to release it.
  5. Now unplug the other ribbon. The ribbon attaches like a plug and socket. Simply lift it up to unplug it.
  6. The ribbon you just unplugged is the flex of the phone, so you have to unscrew the lower part of the phone to remove it completely.
  7. To open the lower part, you have to open the back cover and remove the battery,
  8. Unscrew the screws you see, than split it open with a credit card or the tip of your finger, apply a little force to open it.
  9. Then unscrew the board, you will see where the other end of the ribbon is connected on the board, then you can remove it and fix a new one.
  10. Reverse the process to reassemble the phone together.
Take care
Jun 22, 2010 | Motorola Mobility RAZR V3
Peugeot 307 speaker changing
There is no way around with out removinf the panel, u ll have to remove then only u can gain access to the fixing screws to replace the speaker.
For your Sunvaley...
You have to remove all the below listed to remove the door pad
  • The switch block bolt
  • The switch block
  • The exterior mirror fasteners interior cover
  • The interior opening control trim
  • The 3 fasteners (screws) 3 on the trim
  • Slowly pull out the trim without excessive force, to avoid brekage of the clips inside
Apr 25, 2009 | Peugeot 307BR Wrist Watch
Samsung m510 (envy) screen broken
contact any samsung service center
Jan 02, 2009 | Samsung SPH-m510 Cell Phone
LG PRADA TOUCH SCREEN FAILING TO RESPOND
the lcd could need to be replaced if that is happening
Jun 26, 2008 | LG Prada KE850 Cellular Phone
Screen on Razr
You will need a hot air soldering/desoldering gun for the work. Not possible. Only a trained technician can do it.
Oct 27, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
41 people viewed this question
Top Nextel Cell Phones Experts
Marvin
Marvin
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
