Battering wont charge
SOURCE: I have a Cannon ES55
Check the voltage on the charger, now remove the battery off the cradle and check the voltage that appears on the terminals that touch the battery terminals. If there is sufficient voltage more than the battery voltage it should be good. Now make sure that your battery voltage is good and the battery though NEW has not been inthe shelf for long. If so it would have developed back EMF and will not charge. So check this out. If ther is no voltage a the cam terminals from the adapter then you will need to open and check for the charging circuit, a possible failure of the regulators. Hope you try this out. Good day
SOURCE: where is the serial no.
To find the serial number remove the battery and look for the serial number next to a qr code.
