Question about Sony Handycam CCD-TR427 Hi-8 Analog Camcorder
Connection problems Have just bought camera 2nd hand without instructions, Cannot find how to connect earphone or tv leads, can you help please?
  • tonyearthy Nov 13, 2008
    Should read "PDF file"
Managed to find PGF file with operating instructions for a very similar camcorder on the web.
Thank you for your interest
Posted on Nov 13, 2008
Can I attach earphones to this tv?
If there is a headphone jack(earphone) provided, then yes you can.
press the helpful button and check link below
How to Use Headphones With Your TV
How to use headphones without tv jack
Jan 10, 2016 | Televison & Video
Connect hdmi goodmans tv
Forgive on this one but I do not have a soundbar but wonder if it has any other connections like phono for input as to me hdmi would be a strange choice. Hdmi leads are mostly alike in they are fully wired and carry a wire which directs a device to listen to it when turned on, also some hdmi sockets (like the old scart) are blessed with options.
Some may be input only while others set for in and out so it may be worth swapping connections on your TV to see if this changes the habit, though for me I would look to see if this soundbar has other sockets to use like phono (same with your TV if it has phono or scart socket options). Your TV instructions may show their ideal connection setup, otherwise you will have to shutdown your other item to stop it commanding the TV to switch through its sound. This "problem" is an old one with people using scart leads then I used to cut pin 8 (its control wire handing the descision to a user) but this new lead combo I do not know.
Hope this helps.........
Aug 29, 2017 | Samsung LN32A330 32 in. LCD TV
Trying to connect Sony wireless audio unit to tv using a jack lead,plugged into unit. And it began buzzing,connected to headphone socket on tv (as instructed)
since it was covered with warranty just return the unit to the supplier or ask them for assistance.by the way what unit have you been hooked up in the tv.
Aug 16, 2012 | Televison & Video
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
2nd tv will not find signal after electric power cut
usually a surge like that can damage the circuitry
Jul 21, 2012 | Televison & Video
I have a canon slr camera and wish to display the pictures on my tv. i connect the appropriate cords, turn camera on but nothing happens. what are the right steps involved?
Assuming that you've connected the colour-coded leads correctly to the matching tv input sockets then you just need to use the tv remote to select the correct AV input and ensure that you switch the camera on. If you don't know how to to this then check the instruction book for your tv remote.
Note that you should make/remove the cable connections when the camera is turned off.
If this has helped then please return the favour by rating my answer, if not then please add a comment with the exact make and model of tv (and remote control if it's not the original one) and I'll do my best to provide further help.
Oct 14, 2009 | Canon EOS-AE-1 35mm SLR Camera
Logitech wireless earphone not connecting
the problem may be in logitech earphone......after using some days....it may have got repaired....if it is repaired then the connection problem will come....otherwise if you are using antivirus....check the firewall.....if the firewall is not allowing skype to connect to internet....these problems will arise....i am a software engineer and i have experience in these areas....thats why i am suggesting this idea....try this...it will work.....
Sep 19, 2008 | Logitech Cordless Internet HandsetĀ for...
Samsung MAX-945D
purchase an sterio audio cable for computer out put. connect it to the computer output sond, and the on the other side connect to both pin in aux. then play sond and press the aux button of your dech samsung_max_945d.
i have this manual, i you need just tell me than i will email. to you.
Jan 20, 2008 | Audio Players & Recorders
Sony Handycam CCD-TR427 Hi-8 Analog Camcorder Logo
57 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
