Our tech spilled fuser oil on the floor. How can I clean it up?
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
I would use Goop!!! it's a spray that removes gunk, oil, gum etc.
Posted on Nov 12, 2008
Oil leak onto garage floor either coming from oil pan gasket or oil filter not sure wich one
Clean the filter and pan with a spray cleaner, run engine for a few miutes.
recheck oil leak.
Probably is rear main seal leaking, very common trouble.
If not leaking much, keep drip pan under car to keep floor clean and drive on.
Most cars do leak after they age a little. The black line in the middle of the road is oil leaking from cars. Very common.
Sep 28, 2010 | Honda Passport Cars & Trucks
What do i use to clean off the gear oil i spilled on the differential
i'd try a spray can of BRAKLEEN,don't get into eyes
Jan 15, 2010 | 2008 Jeep Wrangler
I installed a new fuser oil cartridge in my Docucolor 12. After about a week I found the oil was low again and we had only made a few hundred copies. When we pulled the unit away from the wall I found...
u need a new oil tank. this is the yellowy/brown plastic bit where the oil sits in. if not you might have a blockage in your oil system in the fuser itself causing it to spill out. if the oil is on the trays its more than likely the oil tank
Jun 18, 2009 | Xerox DocuColor 12 Printer
Where is the fuser area in the Canon D860?
The Fuser is the heated section of the machine, the last process before the copy leaves the main portion of the machine.
You should find two rollers, upper and lower, if these rollers are unable to clean themselves excess toner will build up on the rollers and get passed on to copies later on. you can clean these rollers with some alcohol or similar solution. Be sure the machine has been turned off for awhile as these rollers are extremely hot when at operating temp.
The second question would be, why is the system not cleaning itself. Sometimes if the copier has been on a large run with a lot of dark areas it can overwhelm the cleaning unit, but if this is not the case you will need to determine what is wrong. The Fuser is usually cleaned by a cleaning roller, cleaning web or cleaning wick.
These cleaners are usually white when new, brown to black when well used.
They are usually oiled with a silicone oil which prevents the toner from sticking to the Fuser rollers, so the cleaner may not look too dirty but may be out of oil.
This may be a part you can change or you may have to call in a Tech.
Hope this helps.
Apr 16, 2009 | Canon ImageRUNNER 1670F Copier
Toner leaks from cartridge while in machine.
Tech re-furbished the drum and the problem went away. Apparently, not all drums you buy are the same quality. Some completely replace the drum material, while others simply clean the surface which is not the correct process. I guess you get what you pay for.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
The copied paper is half soiled with fuser oil.
Pull out fuser unit and remove the top. ( let machine cool down, VERY HOT!!) does the fuser web need replacing ( looks like a white paper towel roll) it has fuse oil on it. is it overflowing?? try cleaning, do not spill on floor it is very slippery and hard to clean up.
Jan 22, 2009 | Canon CLC 1000 Color Copier
Oil Leak spilling oil on driver's side floor inside car
if it was an oil like substance it sounds like it might be freon from your a/c a line might have finally broke in the HVAC witch is in the dash and that sound like the problem hope this helps
Jan 17, 2009 | 1990 Toyota Corolla
Error Code SC570 for copier Aficio 1224C
It could be covering the sensor. Clean the fuser oil sensor off and see if it goes away.
Dec 17, 2008 | Office Equipment & Supplies
Docucolor 12 spills fuser oil
Pretty much all you can do is rebuild the fuser, either the meterins blade or wick are work out.
Mar 19, 2008 | Xerox DocuColor 12 Color Copier
