Question about Ecoquest Breeze AT Living Air Purifier
Smell in the air
My Breeze AT produces a smell in the air when I have the purifier on. It does not clear up. I have replaced the filer and the plate. The smell goes through my whole house and does not smell healthy. My chest kind of hurts after breathing this in.I've had it for 3 1/2 years. I hadn't used it for about 6 months. I cannot use the sanitizer because I have a dog in the house during the day. The company wants $189 to refurbish it, but I think there is a definite problem.
  • bbogerbkg Dec 31, 2008
    I cleaned the filter and let it dry. The air just stinks. I want to turn it off but the person I work for said it would get better and it's suppose to that. I'm getting a headache from the smell. Help
  • Jon Stignani
    Jon Stignani May 11, 2010
    What kind of smell?
    Is it like burning car brakes/electrical insulation, or something else?
    Thanks in-advance.
    Jon
  • 31 Answers
If the smell is not electrical as JEShandyman was asking, but rather from something trapped in the lint filter you could try putting the unit under a box and put it on sanitize. Let it run for 30-60 minutes and see if that cleared up the problem. Washing and drying the filter first is a good idea.
You should never get a head ache from the smell the machine produces. The fresh air the machine produces reacts with the odors and contaminants in the environment and that can potentially create other smells. If that happens you should scale the machine back to a lower setting and take it very slowly and ramp it up day by day. This is something you should have been told by the person who sold you the machine to begin with.
I hope this helps.
Eric
Posted on Feb 02, 2009
I don't smell the "new
You mean you're not smelling the ozone. You can't smell ions. I can send you one. What is your email?
Jul 04, 2011 | Ecoquest Breeze AT Living Air Purifier
Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
I no longer smell the ozone smell that i used too.
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers.
May 29, 2010 | Ecoquest Breeze AT Living Air Purifier
Cleaned plate but unit doesn"t have the smell that it had
Mar 06, 2010 | Ecoquest Breeze AT Living Air Purifier
THE WET DOG SMELL
try soaking the grid plate in ammonia
Jan 11, 2009 | Ecoquest Flair Air Purifier
No ozone smell
This generally indicates that the plate is cracked or not making proper contact. Pull the plate and look very closely as even a tiny microscopic crack anywhere on the plate will produce these results.
Nov 08, 2008 | Ecoquest Breeze AT Living Air Purifier
pull out the plates and clean contacts that touch plates with rubber eraser then put plates back in check switch on back of screen to make sure its making contact.
~~~creekkid~~~
Dec 19, 2007 | Alpine Air XL-15 Air Purifier
Ecoquest Breeze AT
When you clean this unit, the plate should be soaked in a 50% amonia to water solution for about 8 minutes. Take a toothbrush and scrub each side of plate and let copletely dry. Take a qtip and dip in rubbing alcohol and swab each of the metal electrodes that touch the plate....This should have that freash air smell back again.!!
Nov 08, 2007 | Ecoquest Breeze AT Living Air Purifier
Unit stopped smelling
Whenever you clean or replace the plate, you must also clean the contacts that touch the plate, and all supports for the contacts. Clean them with 70% or higher isopropyl alcohol and Q tips. You should also clean the ionization point with a Q tip and alcohol, remove and clean the fan and oil the fan motor front and rear with a drop or two of sewing machine oil. Replace the fan so that it is flush with the end of the shaft. Make sure that the contacts are firmly against the ozone plate when you replace it. They sometimes barely make contact and then don't work well. You can bend them enough to make them fit firmly.
Nov 06, 2007 | Ecoquest Breeze AT Living Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
236 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
