Ip2600; serial HKNA54802;CD ROM QH 72929-01. After last print job, 2 sheets fed through at the same time. Perfect copy on top. Now, Will not feed paper on left side, attempts to print. Stops, displays 3 yellow flashing alarms and one green. Will not print after pushing yellow alarm button. Print job reads out,"1 one job wating." No paper jams, gray tab to the left for letter not envelop printing. Need helpl. thanks
  • 3,422 Answers
Please reset your printer by unpluging all the cords of the printer for 10 min. even the power cord.After 10min. plug in the cord and turn on your printer.
Posted on Nov 12, 2008
  • Priya darshan Nov 12, 2008
    Also perform the below steps:
    1) Power off printer
    2) Hold RESUME button then press and hold POWER.
    3) Hold POWER and Release RESUME.
    4) Press RESUME twice then release both POWER and RESUME buttons.
    5) When the indicator lights steady, press RESUME 4 times
    6) Press power to set data.
    7) Print away!
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Won't photocopy / warning light flashing /
The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
Jul 16, 2009 | Canon PC170 Copier
Printer keeps reading paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Canon MX300 Office All-In-One Printer
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
Cannon pixma 1600
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it), and then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Nov 25, 2007 | Canon PIXMA iP1600 Printer
29 people viewed this question
