Question about Siemens 24 in. SE55A560 Built-in Dishwasher
Dishwasher does not take final rinse water
Our dishwasher does not take the final rinse water. We had problems before that it would not take any water and we changed the electronic intake valve. This worked for a bit and then it started not to take the final rinse water. It will sometimes work if you give it a shove on the front. Otherwise we have to pour water in.
5 Suggested Answers
SOURCE: dishwasher runs through the cycle but doesn't stop
most likely a new controller switch only...
Posted on Mar 05, 2008
SOURCE: kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Posted on Jan 02, 2009
SOURCE: No power for my Siemans SL84A dishwasher
Not a solution but a cause for my DW having the same problem. One of the four wires going to the On/Off switch shorted and burned. I never lost power to the unit, as far as I know there is no reset button of fuse. I rewired the unit and ran several washes without overheating or shorting.
Posted on May 03, 2009
Daniel S
  • 4323 Answers
SOURCE: The dishwasher is not cleaning
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 16, 2011
Dishwasher does not drain
Dishwashers do not drain the water has to be pumped out of them.
If the water is not being pumped out on any cycle then the pump has failed and you either need to replace the water pump (which will be quite expensive) or buy a new dish washer. Pump failure is a pretty common in part because of the amount of debris many users don't rinse from items before placing them in the washer. Also the filters at the base of the washer need to be removed and cleaned frequently and this is often neglected.
If the water is only remaining in the washer for the final rinse cycle but is otherwise being pumped out on the wash cycles, then the issue will be with the electronic control board.
Dec 08, 2015 | Frigidaire Dishwashers
All the water is not draining from the bottom of the machine. How do we fix it please?
It does not drain it has to be pumped out by the pump on both the wash and rinse cycles.
If the pump is not working on any cycle it has most likely failed and needs to be replaced.
If the pump is not drawing water out of the machine in the final rinse cycle only then there will be an issue with the electronic control board not activating the pump in the final cycle.
Nov 21, 2015 | Dishwashers
Why won't my Bosch nextt 100 series washer add water to to rinse?
First you must check water in drum. If is inside drum water than could be problem with drain water. If is not, than is problem in phase "intake water". In this case could be problem with electro-valve for rinsing cycle or wiring between valve and programmer or electronic depending of appliances and finally electronic or programmer.
Dado
Aug 05, 2015 | Bosch Washing Machines
Hobart SR24H dishwasher after rinse cycle the same time pampas water in and out of the dishwasher, two pipes are opened and working
Hello.
As per my personal opinion this is normal because for the final rinse you have a small booster or boiler..
When you turn on the machine..it starts fill and also the booster for the final rinse.
You start the machine..wash cycle...rinse cycle..
Now..new water(from rinse booster) is coming on the tank in order to rinse the dishes..on the same time the machine drains the excces water from the rinse(over flowing) and fills up the booster with new water.
Should be like this
Good luck
Jun 29, 2013 | Dishwashers
I have a ADG450 about 7 years old, the problem is there is dirty water left at the bottom of the dishwasher after finishing the cycle and the dishes look as if they have had the final rinse in the dirty...
check the pipe leading from the dishwasher to the outlet, maybe under sink. this needs to be raise up as water will flow back into washer. Had this problem myself, felt foolish when the repair man just tied it up and left. !
Jan 03, 2011 | Whirlpool ADG450 Slim-Line Built-in...
Dishes on the top rack not cleaning properly
Had similar problem with our Maytag dishwasher--we removed all spray and screen components to the inner case, cleaned the intake screen below the lower spray arm, repaired a split upper spray arm, and inspected everything for cracks or other distortion. All of this helped some, but finally improved things by changing from liquid detergent to a "packet" type. Our water is somewhat hard and builds deposits on the screen at the bottom. Run a no-dish cycle with a cup of white vinegar in the bottom.
Aug 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
Cloudy glasses with hard white calcium build-up
the problem is not your dishwasher or your detergent. the reason for these spots is hard water. www.dishwasherfilter.com makes a new product to address and fix this problem. it filters the water going into your dishwasher leaving your dishes spot free with every load. it is very affordable and fits right under your sink. it is guaranteed to work or your money back. you will love this product. thanks
Apr 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Cloudy Dishes
Salt? i know you said you have soft water but probably not enough, the salt replenishes the resin beads so you get a rinse with pure water on the final rinse.
Jan 16, 2009 | GE 24 in. GSD2120C Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Siemens 24 in. SE55A560 Built-in Dishwasher Logo
37 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
