Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Intermittent loss of mobility, get beep beep sound
Wiggling the key switch a number of times restores mobility. We have less trouble if we do not turn the switch off when stopping.
  • 118 Answers
I sounds like the switch is not making contact relieably. Make sure your key is clean and if that does not work, than the switch inside the console will need to be replaced. Contact Pride Mobility for a technician local to you.
Posted on Nov 27, 2008
My shop rider chameleon scooter beeps when I turn it on but it won't move the battery shows fully charged
Make sure the lever that disengages the motor from the wheels is in the engaged position. If it beeps a certain number of times then stops for a few seconds and then starts up again, count the number of beeps. That is a trouble code. You will need the owner's manual to determine what the code means by the number of beeps.
Dec 17, 2015 | Health & Beauty
Why do I have an intermittent problem with ABS and power steering lights?
Bad or loose intermittent wire connections to and from sensors. Some unauthorised mechanic has been working on the car? Take it back and talk to the service manager, or the shop owner.
Apr 14, 2015 | 2010 Volkswagen Polo 1.2
2003 harley softail will not start
Did you pull any error codes (Diagnostic Trouble Codes)?
1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector. Other models will be under the seat.
2. To activate the diagnostic feature,follow these steps.
a. Create diagnostic test wire or use a female spade clip which will bridge the two terminals perfectly.
b. Install diagnostic test wire/clip across Terminals 1 and 2 on the data link connector, they are marked.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A "trip" consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diagnostics manual you're not going to know what they mean.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensoropen/low
22 Current 12 MAP sensorhigh
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensorvoltage low
26 Current 15 IAT sensoropen/high
27 Current 24 Front ignition coilopen/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coilhigh/shorted
30 Current 25 Rear ignition coilhigh/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switchopen/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensorhigh
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensorvoltage low
78 Historic 15 IAT sensoropen/high
79 Historic 24 Front ignition coilopen/low
80 Historic 25 Rear ignition coilopen/low
81 Historic 24 Front ignition coilhigh/shorted
82 Historic 25 Rear ignition coilhigh/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Dec 28, 2013 | 2003 Harley Davidson FXST Softail Standard
Retrieve codes for 2003 road king
2. To activate the diagnostic feature, proceed as follows:
a. Create diagnostic test wire or use a female spade clip.
b. Install diagnostic test wire across Terminals 1 and 2 on the data link connector.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A "trip" consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diognostics manual you're peeing into the wind.
10 43 Loss of power train security status
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
56 Current 41 Ignition switch open/low
74 Historic 12 MAP sensor high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
Apr 11, 2013 | 2003 Harley Davidson FLHRCI Road King...
2001 hyundai accent won't crank
Shifter ?? why do you bother with a lazy mans gearbox ,nothing but trouble cant beat the manual version ,from your description it sounds like a inhibitor switch failure but i couldnt be sure without the old one cell brain box under the bonnet to be sure
Apr 14, 2012 | 2001 Hyundai Accent
Ignition key won't turn
It sounds like you have a bad tumbler/key cylinder
Apr 10, 2010 | 2001 Toyota Sienna
Beeper sound when pressjng forward trigger no drive .you hear the same sound if you turn on key if in free wheel mode.
Usually the beeps are a series of beeps. If you count the number of beeps, that will tell you what to look for. Refer to the owners manual or check with a dealer to find out wht that number of beeps tells you.
Sep 17, 2009 | Health & Beauty
My Sonic Pride SC52 very often gives a 7 beep error
we need to replace the throttle potentiometer falt.
should cost around 150. easy to replace. smithrm70@hotmail.com
Aug 25, 2009 | Pride Sonic 3 Wheel Portable Scooter
3 beeps after shut off.
Sounds like a shorted key fob or intermittent BCM problem.
Aug 05, 2009 | 2006 Saturn Aura
Nokia 9300i
It happends sometime ago with me too, the solution is;
1) Just check the number in the contact if not present add it!
2) Make a backup of the content using backup.
3) Format your mobile!
4) Restore your mobile content.
Format your mobile!
To Format your mobile proceed as follow;
Remember the mobile battery should be fully charged!
Take Out the battery & Insert it again! If the mobile is not ON turn it ON then quickly press Ctrl + Shift + F You see a warning msg saying something like! Do you want to format the phone! Press format & your mobile will be restored to its default factory settings.
Mar 02, 2008 | Nokia 9300 Smartphone
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
392 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
