Question about SanDisk Sansa Clip MP3 Player
Charging my 2gb sansa clip
Drained my battery all the way cause i left it on all night . never charged it before and i dont have the installation cd
  • 8,596 Answers
You can charge it by leaving it plugged into the computer for 3-4 hours (usually less).
Posted on Mar 23, 2009
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
Feb 04, 2009 | SanDisk Sansa Clip MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Battery
Latest firmware
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
MP3 player
I think it over charged. I left it on all day. When I returned home it was turned off. Before when I tried to turn it off it wouldn't. I turned it back on and it was fine, but the battery was very low. I charged it for a smaller amount of time. It is now fine and working like normal!
Thank you,
Fixya.com
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB
yu charge it erveryday, and yuve been using it everyday, so that means that it needs to charge, if it says connected tocomp and charging that means that it needs more electricity in its battery to keep, its battery running.
Jun 11, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
78 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
