Question about Mitsubishi WS-55711 55" Rear Projection Television
Mitsubishi WS 55711 convergence problem only with some inputs
Just replaced the convergence IC and with most inputs including cable or component (480i and 480p) convergence is great. However, when going to 1080i using the component input, blue is not in alignment anywhere. When hooking up an off-air antenna to DTV coax input, same thing. Any reason the choice of input or resolution would throw off convergence?
  • Mitsubishi Master
  • 3,459 Answers
Projection TVMitsubishi WS 55711 convergence problem only with  - 2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
    Mitsubishi WS 55711 convergence problem only with - 2_bing.gif"h_mi">Screen looks 3D2_bing.gif
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
  • photos of convergence problems.
    Here is a quick test....
    Using your original remote go-to the settings menu then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move RED and BLUE in all directions - up, down, left, and right.
    Mitsubishi WS 55711 convergence problem only with - 2_bing.gif't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
    Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
    93a1209.pngCONVERGENCE SOLUTION
    You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
    This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Posted on May 30, 2010
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Tip
Mitsubishi WS-55711 Manual Download
Download Mitsubishi WS-55711 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55711 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-55711 VChip Password
Bypass Mitsubishi WS-55711 Front Lock
on May 03, 2010 | Televison & Video
Tip
Download Mitsubishi WS-48511 HDTV Manual
I hope that helps.
on May 03, 2010 | Mitsubishi WS-55711 55" Rear Projection...
The tv says that its outputing at standard 480i resolution. how do i set it to 1080i?
You have to use the RGB component inputs on the jack panel and make sure you set your cable box the same. If your using basic cable screwed into the antenna input jack then that's the max you'll get is 480i. You have to use the RGB input to get 1080i with that model.
Dec 20, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55711 Green sagging
replace the convergence ics again.sounds like you got a bad ic.realigned the green convergence geometry after reinstalling the ics.you will need to go into the techician service menu and go into the cross-hatch pattern to do the alignment.
May 27, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Tip
Bypass or Reset Mitsubishi WS-55711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 55711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Tip
Bypass Mitsubishi WS-48511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-55711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-55711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Blue convergence wont adjust
That is one of the yoke return resistors, it's 3.9 ohm 1 watt. Replace them with a 2 watt resistor of the same value.. Best place would be Acme out of Florida http://www.acme-sales.net/index.shtml bag of 10 for 1.99
plus shipping.
If R8c22 is bad its almost certain that R8c21 is bad also and that mean the blue was probably distorted... But check all the returns with an analog meter including R8c19, R8c20, R8c22, R8c23, R8c21, R8c24...
Bill
Jul 20, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Scrolling lines
Try using a DVD though the component input (need a 480P out ). If the pix si ok I wouldsuspect the cable box. If the problem is still there I would suspect a video switching IC or a Leaky regulator.
Oct 15, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Tip
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.
Mitsubishi Convergence IC Part # List (complete)
Ref # / Part # / Part Name & Description
CHASSIS: VZ7
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
CHASSIS: VZ8
MODELS: VS-45607 / VS-50607 / VS-60607 / VS-50707 / VS-55707 / VS-60707 VS-70707
IC8C01 267P141030 HIC - STK392-110
IC8C02 267P141030 HIC - STK392-110
CHASSIS: VZ9
MODELS: VS-45609 / VS-50609 / VS-55609 / VS-60609 / VS-60719 / VS-70709
IC8C00 267P155010 HIC - STK393-110
CHASSIS: VZ6-V15
MODELS: VS-70803 / VS-80803 / WS-65903 / WS-73903
IC8D01 267P120010 IC-H STK392-040
IC8D02 267P120010 IC-H STK392-040
MODELS: VS-50800 / VS-50803 / VS-60803
CHASSIS: V16
MODELS: VS-50805 / VS-60805 / WT-46805 / WS-55805 / WS-55905 / WS-65905 / WS-73905
IC8D01 267P120010 HIC - STK392-040
IC8D02 267P120010 HIC - STK392-040
CHASSIS: V17
MODELS: WT-46807 / WS-55807 / WS-55857 / WS-55907 /WS-65807 / WS-65857 / WS-65907 / WS-73907
IC8C01 267P150010 HIC - STK392-570
IC8C02 267P150010 HIC - STK392-570
MODELS: WS-55908 / WS-65908
CHASSIS: V18
MODELS: WT-46809 / WS-55809 / WS-55819 / WS-65809 / WS-65819
CHASSIS: V19
MODELS: WS–55859 / WS–55909 / WS–65869 / WS-65909 / WS-73909
IC8C01 267P155010 HIC - STK393-110
CHASSIS: V20B
MODELS: VS-A50 / WS-A48 / WS-A55 / WS-A65
CHASSIS: VK20
MODELS: WT-42311 / WT-A42
CHASSIS: V20
MODELS: VS-50111 / VS-60111 / WS-48311 / WS-55311 / WS-55411 / WS-65311 / WS-65411 / WS-73411
CHASSIS: V21
MODELS: WS-48511 / WS-55511 / WS-55711 / WS-65511 / WS-65611 / WS-65711 / WS-65712 / WS-73711 / WS-B55
CHASSIS: K20
MODEL: WT-42313 / WT-42315 / WT-42413
IC8C01 267P173010 HIC - STK394-250
IC8C02 267P173010 HIC - STK394-250
CHASSIS: V22
MODELS: WS-48313 / WS-48413 / WS-55313 / WS-55413 / WS-65313 / WS-65413
CHASSIS: V23
MODELS: WS-48513 / WS-48613 / WS-55513 / WS-55613 / WS-55813 / WS-65513 / WS-65613 / WS-65713 /
WS-65813 / WS-73513 / WS-73713
CHASSIS: V24
MODELS: WS-48315 / WS-55315 / WS-65315
CHASSIS: V25
MODELS: WS-48515 / WS-55515 / WS-55615 / WS-55815 / WS-65515 / WS-65615 /WS-65815 / WS-73615
on Oct 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55711 55" Rear Projection Television Logo
314 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
