Question about Compaq Presario 5000 PC Desktop
My Compaq Presario Will not even show curser after start up
After start up On Compaq Presario 5WV270 can not even get the curser to show on monitor. From what I can see the fans work and I think cd rom is working but I can not get anything to display on monitor.
The monitor is good.
  • Brian Jones May 11, 2010
    You know that the monitor is good becuase you conntected it to another system? Do you have a second montir or LCD that you can connect to the system.
    Does the system past the power on self test? ( you should hear a beep when this happens)
    When the system is booting do the num lock scroll lock and caps lock indicator lights light up and then turn off or are they flashing?
    If the system is not posting then you need to answer the following.
    have you added any hardware to the system?
    have you done any upgrades to the BIOS or Firmware?
    If you have added any hardware to the system, then remove the added hardware and try to boot it up again.
    If the system is posting and another monitor or LCD does not work then you most likely have a video card failure.
    Problem Solver:
  • 13 Answers
Reboot and keep pressing F5 go to safe mode if u can see the screen , u need a video driver ,or try reformatting and re installing windows,
Posted on Jan 11, 2009
COMPAQ presario cq57 has a blue screen and white curser
This means nothing specific, try to load Last known good configuration, by holding F8 key right after power on, until it shows Windows boot options. You should also check memory, hard disk drivers and viruses, but this is much longer explanation, so ask if needed.
Dec 01, 2012 | Compaq Presario Notebook
Computer comes on but nothing show on monitor u can hear the fan but nothing show on the monitor
  1. Make sure that your monitor cable is plugged into the back of the computer, also sometimes depending on the setup of your computer there can be 2 places to plug you monitor into on the motherboard, if you see another port that looks the same try plugging it into that one and try again.
Feb 15, 2011 | Compaq Presario 5WV270 (202498-003) PC...
I got a Compaq Presario SR1903wm .with red blinking light !!! power's up for about 20 seconds then shuts off !! doesnt even start up in Bios !! Dont know what to do !! should i replace the power supply...
check the ram memory ..if this shows up OK (verify it in another computer with the same specifications ) ...than the CPU is to blame ..open it up ..and remove for a few seconds the Bios battery to see if you messed up with the temperature settings ..This will reset to factory settings ..and if there is teh case with temperature limits too low set ..than it will power up after ..if it is the CPU you will have to change it
Jan 28, 2011 | Compaq Presario 5000 PC Desktop
I am attempting to replace the orignal monitor for a compaq presario with a dell flat screen. how do i change the driver for the monitor
You should not need a driver for the monitor to work, as long as you are using Windows XP and above
as this OS will , or should work with all monitors.
In windows update, you will probebly get offered a driver for this monitor, which you can download and install if you wish
Dec 31, 2010 | Compaq Presario 5WV270 (202498-003) PC...
Starts but black screen, white curser flashing.
your hard drive is failing. try a system restore and if that does not fix the issue you need to buy a replacement hard drive
May 13, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
No touch pad response, no pointer
Boot in safe mode (hit F8 on system start-up). Then once in windows, use the system restore feature found in acessories>system tools once you click the start button.
Sep 21, 2009 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario 5WV270 Has No Oprating System
installing windows 95 on your pc would require you to have a bootable disk (either a floppy or cd)
insert your bootable disk and go to bios settings --> once you start your desktop pc, press Del key
then go to Boot menu and select your frist boot to floppy or cd (wherever your bootable disk is) then exit and save changes.
once your pc boots from the bootable disk goto C:
then make a directory (let's say Win95) --> C:\md win95
then press enter
then goto that directory which you've just created ---> C;\cd win95
then press enter
then copy your windows 95 disk on this directory
once you finished copy, run setup
be sure to remove your bootable disk the next time your pc restarts or change the boot sequence (again in Bios settings) to your harddrive as first boot
hope this helps
Nov 13, 2008 | Compaq Computers & Internet
Compaq monitor blank screen
If its a blank screen all the time that never shows anything not even a screen at startup then it sounds like the internal cable from your monitor to the motherboard of the laptop is unplugged or possibly broken. You need to remove the keyboard from the laptop to check this.
I recommend bringing the laptop to a professional if you have no experience with opening laptops.
Oct 17, 2008 | HP Compaq Presario 1700T Notebook
Need to upgrade from Windows ME to Windows XP or Viesta
Yes you can upgrade to windows xp service pack 2/3 without problem. I recommend you update the bios (rompaq) from the revision on the compaq site, and install at least a second
SDRAM 256mb memory module in it first or it will run slow and hang up frequently. I've been running mine on XP for years, still using it now;) (with 384 memory-one 128chip and one 256 chip)
Jul 26, 2008 | Compaq Presario 5WV270 (202498-003) PC...
Compaq Presario 5000 PC Desktop Logo
170 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
