Question about Breadman TR520 Bread Maker
Display window is unreadable
The window writing is dark grey on a darker grey background... even with a flashlight, under bright lights and a magnifying glass we are unable to ready anything in the window. And whose idea was it to print the instructions on the top of the bread machine is white writing on a butter yellow pale background... it is also impossible to read. The manual shows where there is supposed to be writing above and below the window... part of the writing includes which size of loaf can be chosen to bake and another part of the writing indicates a choice of crust colors. But you can't see the white writing on almost white background and if there is any writing in the display window with arrows to indicate your choice, it is unreadable. And yes, I did remove the film covering the window after it arrived.
  • Eeeeeeeeeekz May 11, 2010
    hello SLPease,
    what would you like for us to help with? how to fix the display contrast?
    I look forward to your posts.
I found this site online as a possible answer to my problem with the Breadmaker. I was hoping for assistance. No answers were given as to whether there is a backlight that is not workable on this machine. Instead I do seem to suddenly be receiving dozens of spam mail and requests from this site to pay for a premium assistance plan if I want an answer. No thank you.
Posted on Nov 13, 2008
How to turn off backlight on iphone 4
There is no separate "back light" setting like there used to be on some earlier phones.
In the Settings app of your iPhone, there is a section called "Display & Brightness". You can use that to make your phone's display brighter or dimmer, but as you have probably discovered, it dims or brightens both the foreground and the background elements together as one.
You can turn it all the way down, which is very dim and hard to see in normal indoor light conditions, but may be preferable in extreme low light conditions like in a nightclub setting, or in complete darkness.
Why isn't there a separate back light setting?
To fully answer this, I would probably have get into more than you ever wanted to know about displays.
First, there is really no background or foreground on today's smart phone displays. The foreground elements and background elements we see on the iPhone are really a graphic illusion created by lighting individual pixels with different colors. All of these pixels are on the same plane, so nothing is really behind or in front of anything else. It's just artistically drawn to look that way.
Brightness is simply an "intensity" setting applied uniformly across all of the underlying individual pixels within the display matrix, and has no relationship to color. For clarity, let's look at the difference between lightness in colors, versus display brightness:
COLOR LIGHTNESS is a matter of how much WHITE (all the RGB colors summed, for example) is present in a given color. This has nothing to do with display brightness.
DISPLAY BRIGHTNESS is a matter of how much LIGHT INTENSITY is applied uniformly across all pixels in the display matrix.
At zero display brightness, you would not see white any better than black, blue, green, red or any other color. You wouldn't see anything.
Why did you expect to be able to control the back light?
Prior to the smartphone era, the displays on early cell phones and pagers (and lots of other devices that had displays) had a lighted background that contrasted with dark foreground elements.
The background intensity was a separate setting on those devices, but that's because the background was the only thing that had intensity. The foreground elements were solid black LCD (liquid crystal display) segments that were used to form characters and very simple graphics and lines.
Everything we see on today's smartphone displays is dynamically drawn by lighting different pixels with different colors at different times. Individual pixels on a Retina display are nearly microscopic in size--they cannot be separately discerned by the eye.
Imagine a matrix of microscopic light bulbs, each of which can separately change to any of millions of colors and levels of brightness at any time, on command. Just imagine the sheer number and complexity of possible commands to control a Retina display!
Even if Apple wanted to provide a new feature that enabled us to separately control the perceived "back light", it would only be an illusion as well.
Such a feature would require some sort of complex algorithm to determine which pixels are involved in what you perceive as the "foreground" elements at any given time, so it could add intensity only to those pixels considered to be "background" at any given time.
Since "foreground" and "background" elements drastically change shape (and location) at any time, such a feature would be pretty daunting to implement.
You might be better off using a pure black graphic as your background image if your goal is to have more contrast to make the app icons stand out.
Cheers,
-=Cameron
Aug 12, 2014 | Apple iPhone4 4G iPhone 4
How to reduce brightness of asus x54h
This is controlled by the menu of the monitor. There is a series of push buttons on the monitor that you use to get to the menu.
May 14, 2014 | ASUS VW193T Monitor
Dell Inspiron Screen Gets Darker
your screen might need to be replaced. soon you wont be able to see anything. replacing the screen should be an ez fix
Feb 28, 2014 | Computers & Internet
At start up my viewsonic va1912wb display blinks several times then i can see the picture but it is dark almost unreadable. Today it went darker than yesterday. HELP!
If it is dark due to brightness adjustment, get that adjusted. Usually when you adjust the brightness by pressing the menu button, the menu screen would not be dark. If everything is dark dark dark and you can only see some display but in very pitch darkness, then your monitor is a goner, backlit for the monitor is dead, and your monitor will need to be replaced. You can fix the backlit tubing, however it is risky, and expensive, and would cost less if you bought a replacement.
Jan 30, 2011 | Computers & Internet
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Ipod touch 1st generation display very dark
You probably reduced the brightness one time, but you just forgot about it. To make the display brighter, do this:
>on your iPod touch screen, go to Settings.
>once the Settings window is open, you'll see Brightness from the list, tap on it.
>now, you drag the button to make the display darker or brighter. drag it to the left to make it darker, to the right to make it brighter. You'll notice the display darkens / brightens simultaneously as you drag the button.
For more iPod touch / iPhone tips, click here. Feel free to comment on my tips if you have other questions.
Mar 05, 2010 | Apple iPod touch
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Phillips cloudy screen
Crt coolant needs changing in the Blue and Gree CRTs red usually isnt affected.
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Breadman TR520 Bread Maker Logo
42 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
