Question about Canon Office Equipment & Supplies
Canon i9900 error 5200 / orange light flashes 8 times
How do you rest this problem.
5 Suggested Answers
  • 390 Answers
SOURCE: Canon i9900 blinking three orange / jam
uninstall it and reinstall it, hopefully it will reset itself then.
Posted on Sep 09, 2007
SOURCE: Canon Photo Printer iP4500
buy new printer
Posted on Sep 05, 2008
SOURCE: Canon i9900 Error reads as follows. Operator
there is something inside the printer, i have the same problem and that was it, a paper or something blocking the headprint to run from right to left
Posted on May 28, 2009
cene765
  • 787 Answers
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Posted on Oct 19, 2009
SOURCE: Canon i9900, orange light blinks 5 times, won't
clean the printheads and the ceramic part_ still blinks 5 times orange and not printing. can anyone help me
Posted on Jan 26, 2011
Cannon i9900, power light is flashing green to orange
Come back to me with the flash sequence of both lights. that tells you what is wrong. Its more accurate than any error code.
May 28, 2011 | Canon i9900 InkJet Photo Printer
Always time sow Error number; 5200 A printer
Here's How to Reset Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Mar 16, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My printer is not working... on screen it displays error 5200? the orange light flashes eight times. what will i do?
my printer is not working... on screen it displays error 5200? the orange light flashes eight times. what will i do?
Jan 18, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Canon i9900, orange light blinks 5 time upon start and continues to blink the same
    This error mean "the print head is failed".You need to replace the print head.It's part number is QY6-0055.
    Nov 19, 2009 | Canon i9900 InkJet Photo Printer
    BJC-8200 beeps 10 times and wont go online.
  • Hi
  • All The Best: Pineworks
  • Oct 06, 2009 | Canon BJC 8200 Photo InkJet Printer
    Printer not working. The light flashes red six times.
    Error Condition Indicator Beeps Error
    Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
    Code
    Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
    Oct 01, 2009 | Canon S400 InkJet Printer
    Pixma i9900 orange light flashes 5 times
    hi guys,
    Flash in orange 5 times indicates that the printhead is faulty so that the printer cannot detect the printhead. Rarely, faulty logic board and carriage unit may cause the same problem.
    Regards,
    Source:
    Canon Inkjet Forum
    Dec 13, 2008 | Canon i9900 InkJet Photo Printer
    I560 error code 5200
    Cartridge Overheat 8 x
    7 times in orange/green 5200 Cause: The print head's temperature is abnormally high tnx and good day!!!!!
    Apr 07, 2008 | Canon BubbleJet i560 InkJet Printer
    452 people viewed this question
    old marine
    old marine
