Question about SanDisk Sansa E280 MP3 Player
How to charge my sansa mp 3 player
I am facing problem with charging my sansa mp 3 player. How to charge do i put it on or off while charging the snasa
  • shubha_mk Nov 14, 2008
    ok i shall try thanks a lot
  • 80 Answers
It doesnt matter if the mp3 is on or off if its off the mp3 turns on when you connect it to the computer or the wall charger then starts to charge if its on it just starts to charge
you should be able to see the little battery charging
Posted on Nov 14, 2008
How do i charge the battery for my sansa
Plug one end of the supplied cable into the bottom of the Sansa, with the Sansa logo on the cable facing up. Plug the other end of the cable into a computer's USB port or a USB charger (such as you might have for your cell phone). If the Sansa is charging, you'll see the battery gauge cycle from right to left.
Aug 30, 2010 | SanDisk Sansa e250 MP3 Player
HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
How to unlock sansa 1 gb mp
Sansa Connect No-Wifi Recovery Tool
Make sure your Sansa Connect player is charged and the HOLD switch is in the unlocked position. Press and hold the power button for 20 seconds, then release it. This will force the Sansa connect player to reset and restart.
If your player still will not start after trying the reset, you may need to run the Sansa Connect Recovery application.
With a copy of the Sansa Connect Recovery application installed on a PC, you can connect your to the device via the USB cable to the PC, and restore the device software to an uncorrupted state.
However, all of your subscription settings and content will be removed from the device.
STEP 1 - Download and install the recovery tool.
STEP 2 - Put your Sansa Connect player in Recovery Mode
1. Press and hold the Power button for approximately 8 seconds to turn off the player.
2. While holding down the Right button, and Volume Up Button,
press-and-release the Power button. Keep holding the Right and Volume Up button. After a few seconds, the player will start and a Recovery Needed message will on the player's screen.
3. Connect the player to a PC.
4. A SanDisk Device Recovery dialog box will appear on your PC. Choose Recover Sansa Device and click OK.
5. Follow the steps in the SanDisk Device Recovery application.
Hope this will help you.
Jan 02, 2010 | Audio Players & Recorders
Mp3
take the battery out for a while and put it back in after about 2-3 mins and charge it
Nov 03, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
MY SANSA CLIP MP3 PLAYER 2 GB
please check on the backlight settings on the "system set" in the Menu, make sure you have a value in there, but if in case the Sansa itself does not seem to be turning on, the check on the battry if it is charged / overcharged. if you have checked on this area and you had the same issue, then you may want to check on the Backlight or the LEDs of your player, better if you consult the warranty of the player before opting to open theunit up by yourself.
hope this helps.
Aug 16, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk, 2 GB Sansa mp3 player won't charge
I was having the same problem with my Sansa e250. My wife has the e200, and we didn't have any problems with that. I saw that someone on here suggested to lock the mp3 player with the tiny metal switch on top, so I did, and the battery charging icon on the bottom of the screen came on and stayed on, and the mp3 player worked. thanks!
Because of this I would suggest checking to see if it's locked or unlocked and then change it to charge it.
Jan 16, 2008 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
