Question about Dryers
Gas Dryer - burner not kicking on
The ignitor, flame sensor and thermal fuse have all been checked. Any other reason this might happen? The blower works but is blowing cold air.
  • 5,911 Answers
Replace the gas valve solenoids (coils). There are usually two of them. One is a pilot position, and the other is a main. It is recommended that you replace them BOTH at the same time. I hope this helps you.
Posted on Nov 14, 2008
Matag dryer not heating
Here is a link to maytag dryer repairs . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
Maytag mlg2000aww ignitor flame doesnt go on when started
This dryer uses a hot surface ignitor to light the burner. test for 110 volts at the ignitor plug after you disconnect it and start the dryer, if voltage is present, replace the ignitor, part# 33002789, if no 110 volts, than you will need to check the thermal fuse located on the blower housing, if hte dryer heats a few times then fails to light after it has warmed up, you will most likely need the coil kit on the gas valve replaced. Pleazer Appliance...
Aug 07, 2012 | Neptune MLG2000A Front Load Stacked Washer...
Why does my gas dryer not ignite to create a flame?
check the thermal fuse and cycling switch on the blower housing,if they both have continuity then check the high limit thermostat for continuity on the burner tube housing and then the flame sensor eye on this tube also and also wipe off its window that faces the ignitor so it can see the flame after ignition,if all this checks good then check the ignitor inside the burner tube as these can burn out
Aug 22, 2011 | Kenmore Dryers
Our Maytag model dg410 quit ingniting. Is it ignitor or something else?
Power from the control Klixon mounted on the blower housing energizes the gas valve assembly when the temp is below 105f and the dryer is set for heat. If that control is open then no power is applied and no heat. If a restriction causes the dryer to exceed 350 for some reason then the fuse next to the control Klixon melts. No power will get to the gas assembly but the dryer will run. On that gas assembly is an ignitor/flame detect sensor, an ignitor, and a pair of solenoids that open the gas valve. The flame sensor must have continuity. If it is open then no power will get to the ignitor. If the ignitor is broken you will also have nothing. The coils will not open the valve without a change in the resistance of the circuit. One of them coils has 3 wires and the other has 2. The sequence of gas valve operation is the flame sensor bi-metal has to open when the temp exceeds 1800f. this kills the power to the ignitor and flips the 3 wire coil so that the ignitor is now a thermocouple and the coils will yank open the gas valve. As long as that ignitor stays hot then the gas will continue to flow out the valve. If for some off reason the gas were not to ignite the ignitor would coold down and shut off the gas and that is your builtin safety. So what goes wrong? Blown thermal fuse, open control Klixon, open flame detect/sensor, open ignitor, or Intermittent coils,(the coils will get hot and quit with age.
Maytag dryer service manual and more HERE
Dec 20, 2010 | Maytag Dryers
No glow from the ignitor. what is the voltage coming in to the ignitor (gas dryer 110-736932100) could the heater relay be the issue?
all you have to do is check continuity across the ignitor. does it have continuity? if no you need to check your thermal fuse for continuity? it is a white peice with 2 wires going to it and sits on the blower houseing. if no then it could be your timer. or yes it could be your flame sensor. that sits off the side of your flume tube where the ignitor is. but highly likly it's just your thermal fuse.
May 15, 2010 | Kenmore 73932 Gas Dryer
My gas maytag dryer has no heat
first check the thermal fuse for continuity in the dryer blower housing/vent,then check the high-limit and/or cycling thermostats and the radiant sensor(flame eye) on the burner tube of the unit,then check the ignitor in the burner tube housing and finally the boost and secondary gas valve solenoid coils on the gas valve body inside the unit near the front entry of burner tube
Apr 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool lg9521xt gas dryer- no heat or flame. I replaced thermal fuse and coil kit, but didn't solve problem. What's next ? The igniter ?
Remove the bottom panel and start dryer . If you see the red glow , then ignitor is ok . Disconnect the plug (2 or 3 wires ) going to the burner and check for 120 volts . If no red glow , replace the ignitor pt # 279311 . If not 120 volts , then , normally , thermal fuse is bad (white piece with 2 small terminals on blower box ) is bad .
Sep 07, 2009 | Whirlpool Dryers
No Heat
Welcome to Fixya
Remove the vent line from the rear and try the dryer.
If it heats then that means there is a clog or kink in the vent line blocking the vent air from exiting which will stop the dryer from getting hot!
If not then it's another one of these problems.
Defective Ignitor (Gas Only)
When heated the ignitor used on your gas dryer must obtain a specific high temperature
in order to activate the flame sensor. This ignitor is fragile and susceptible to cracking.
A hairline fracture that is barely visible to the naked eye is enough to change
the resistance of the ignitor to a point that is will not work properly.
You can test the resistance of your ignitor. You should get a reading of 50-400 ohms of
If the ignitor gets hot and then goes off after about 10-15 seconds and there is
no ignition, the problem is probably not the ignitor. It is most likely the gas valve
coils that are defective.
If the ignitor comes on and stays on, it is the flame sensor that is defective.
If the ignitor is not getting hot it could also be one of the thermostats that is defective.
The power for the ignitor is passed from the timer, through all of the thermostats,
limit switches and fuses to the ignitor. So if you are not getting power to the ignitor
during ignition, you should check the continuity of the individual thermostats and fuses.
Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
Defective Flame Sensor (Gas Dryer Only)
The flame sensor's job is to monitor the ignitor for sufficient heat
to ignite the gas. A properly operating flame sensor will pass a
continuity check under room temperature.
Common Symptoms
If the flame sensor is defective in the open position,
the ignitor will not get hot when the dryer is started.
However, if it is defective in the closed position the ignitor
will get hot, but the flame sensor will not allow the flame to ignite.
In this case, the ignitor will usually stay hot for a long period of
Defective Thermostat
The thermostats are responsible for maintaining the proper temperature
in the dryer. Check the exhaust temperature of the dyer and if the
temperature is above 150 degrees, you will most likely need to change
the operating thermostat.
The thermostat can also fail in the opposite mode.
It can prevent the element from heating at all.
A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw.
These thermostats are often used to control the timer when set to the
Automatic Dry cycle. If the dryer timer will advance in the Timed Dry
cycle but not the Automatic Dry cycle, then the thermostat could be the
Defective Thermal Fuse
The thermal fuse is in series with one leg of power to the motor.
If the fuse is open (no continuity) the motor will not run.
The thermal fuse is located in different locations according
to the model and brand of dryer.
Check the thermal fuse for continuity with a volt/ohm meter.
If it is open, it will need to be replaced
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 25, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer runs but won't heat up
if ignitor is glowing suspect coils on valve assembly if not could be flame sensor on side of burner housing short wires together to find out last suspect thermal fuse located on blower housing ..small white object with 2 wires
Oct 19, 2008 | Kenmore 73932 Gas Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
