Question about Sony DCR-VX2100E Camcorder
Problems connecting a vx2100 through firewire.
Just bought it a few days ago, recorded a commercial video, now can't get it off the camera.
Stick the wire into XP - nothing happerns at all. Camera on or off, tried rebooting in all modes, went through all setttings in the camera.
Vista sees the thing, but when i try capturing video through pinnacle oк adobe - same thing in both - the caprute screen just freezes forever.
Any help would be urgently appreciated. Thanx a lot!
4 Suggested Answers
SOURCE: problem in video capturing through firewire
Hi Sreeki,
You may have solved this problem already but I had the same problem some time ago, so the advice will be a little vague.
From memory the issue is something to do with corruption of a directx file so you could just try re-loading directx.
But the way I found a solution was to try and capture video using windows movie maker and you will find the video capture also fails using this software. However, windows returns an error message (which I cannot remember), and I did a search on Google or something for this error message and eventually found the solution.
It was related to directx and there was a small file that had to be run to repair it.
Hope this helps and I will continue searching for the problem I am now having with my camera not accepting a tape and returning the error message relating moisture......
Posted on Jan 11, 2009
SOURCE: HVR-Z1E Capture problem
Hi George, Sounds like you and I are of the same level with this Cam and editing , would love to compare notes with you if you would care to drop me a line gemfilmsni@yahoo.co.uk
Pat
Posted on Jul 13, 2009
  • 29 Answers
SOURCE: sony dcr-vx2100 firewire not work working
firewire ic may have blown in back supply..check it at a service centre..
Posted on Jan 07, 2010
I want to record onto my DCR-VX2100 from another video camera. What inputs are available on the unit?
s-video input/output and RCA input/output. You can change from input to output via the menu.
Dec 13, 2010 | Sony Handycam DCR-VX2100 Mini DV Digital...
I need the Panasonic NV-GS27 drivers
I don't think you do. According to the Panasonic document "Operating Instructions (PC-Connection)", your camera does not use a USB connection and did not even come with the software CD that was shipped with cameras that have a USB connection.
You need to use the Firewire (DV) interface to transfer videos, and this does not require drivers. It does require Windows XP with service pack 2 (or 3) and DirectX 9.0b/9.0c, and you will probably need to fit a Firewire interface card to the computer's internal PCI bus, as most Windows computers don't come with this connection. Whether this camera will work with Windows 7 is not covered by the document.
You then use various video editing software (commercially available or free downloads from the internet) to download the recordings. The software on the computer controls my Mini-DV camera, including rewinding and play functions to record from the tape in the camera.
You can obtain a copy of the Panasonic document from THIS LINK
Dec 08, 2010 | Panasonic NV-GS27 Mini DV Digital...
I bought a mini DV GR-D31U years ago and the cord that came with it does not allow me to connect to my dell computer. Years ago I asked around as to what could be done to remedy this as far as there being...
You apparently have a Firewire (DV) cable.
This type of camera usually downloads better with a Firewire connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software through the Firewire cable.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As your Dell Windows PC did not come with this interface, you need to fit an add-on Firewire interface card to the internal expansion bus (PCI). This will come with a driver for the card. You can buy one of these cheaply on eBay or Amazon.
Dec 07, 2010 | JVC GR-D31 Mini DV Digital Camcorder
Sony dcr-vx2100 firewire not work working
Oct 27, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Microphone for the vx2100
Can you find a replacement clip that secure the camera (VX2100) onto the tripot stand.
I also need a good powerful external recording mic for the same camera.
I will purchase tapes also if they are available.
My email slimjim133@hotmail.com
Thanks
Jul 13, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Recording onto a mini dv tape from Mac computer Via firewire
I have successfully recorded to a mini Dv tape from my computer however I connected my PC to the VX2100 using the RCA inputs. I have an adapter that I purchased from best buy that provides the RCA input/output. If your able to connect that make sure to...
1. Turn you VX2100 to Play/Edit mode (not camera mode)
2. Insure the program on your mac has an external output otherwise you won't be able to record.
3. See if your video editing software (if your using one) has an option for record to tape or to camera. I use Vegas Studio and it has an option for that.
Hope this helps. Good Luck!
Jun 23, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
LCD video camera to vcr
Hello!
You need an A/V cable (audio-video).
That is a bundle of three RCA male-male cables and they are marked with yellow (video) white (Left audio) and red (Right audio) for easy identifiying.
Connect either to the front or back of the VCR, make sure you have the right input selected.
If you have your TV on and on the video channel you should see the movie from the camera when playing it.
If you can see it then just record.
To record your VHS tapes to a computer you need either a TV-card or a digital videocam with a firewire connection.
If you have a TV card (affordable nowadays) or video capture card you can connect your old videocam directly to your pc using a S-video cable or the analog A/V cable described above.
Firewire PCI cards that is compatible with any desktop PC are not expensive these days. (if you dont allready have a built-in connection.)
You will also need a "4-6" firewire cable (also called DV-firewire cable)
Connect the old cam to the DV cam using one of the above cables.
Connect the DV cam to the PC using the firewire cable.(You may have to set the DV cam to a "record from external source" -mode)
You will also need software to record the signal to your harddrive, there is a lot of freeware programs you can download on the internet.
If you use windows you can use the "windows movie maker" software.
Good luck.
May 01, 2009 | Panasonic NV-GS15 Mini DV Digital...
Dcr-vx2100 dv interface connection problem
camera firewire connection will not respond to iMovie or Finalcut even when using a new cable - what could be the problem?
Nov 12, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Audio dropout
take it or ship it to video tech service. they will clear it and go from there. it may need some tension adustments in addition. The guy there is super cool.
Aug 18, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony DCR-VX2100E Camcorder Logo
60 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
