Question about Sony PCS-1 (PCS1) Video Conference
Sony pcs-1 internatl audio path
On the setup page there are 3 settings for Echo Canceller.
1. Off
2. Internal
3. External
Does selection 3. External refer to an external Echo Canceller connected to the PCS?
Is the Internal Echo Canceller in the path between the mic and the audio input switch point? Or is the Internal Echo Canceller down stream of the Mic and Audio input ciruits?
Do you have an internal Block Diagram of the PCS-1 than you could email to me?
Thank You
5 Suggested Answers
SOURCE: microphone
For microphones with a 3.5 mm miniplug you can use a plug-in at the front of the camera. There is a little plastic cover over the hole under the word "MIC". I would call this an emergency solution because for most recording purposes you would want a microphone with XLR connectors.
This camcorder comes with an external shotgun condenser mic and XLR adaptor. If you have the operating instructions that come with the camera, you can turn to page 29 where there is a description of how to install the supplied external microphone.
When you slip the hot shoe plug of the XLR adaptor into the intelligent accessory shoe, the internal microphone is by-passed. In case you do not have the operating instructions you can download them from the Sony manual site.
http://esupport.sony.com/perl/select-system.pl
Put briefly, Attach the XLR adaptor to the accessory shoe on the top front of the camcorder and tighten the screw of the adaptor. Connect the hot shoe plug of the SLR adaptor to the intelligent accessory shoe of the camcorder, located behind the adaptor screw. When you push the hot shoe plug into place you should hear a click. Sometimes you have to use a little strength to get it correctly seated.
I hope this helps.
Posted on Jan 29, 2008
  • 3 Answers
SOURCE: Sony PCS-1 Video Conference
in order to help you:
- are you behind a firewall?
Sounds a lot like a firewall issue.
You may contact us for free troubleshooting:
Contact
Furthermore this is our detailed PCS-1P page.
Best regards,
Andy
Posted on Feb 19, 2009
SOURCE: PCS-1
Reset password sony pcs-1
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN.
Posted on Apr 04, 2009
SOURCE: Sony DCR-DVD201 internal mic does not work.
Hmmmm well I wonder if you aren't being a tad unfair, we must have more faith in professionals that we use to repair our equipment. IF you have taken it to an authorised service center that actually deals and repairs these items as a matter of course, i would take what is stated as gospel. Most often professionals do NOT need to hide behind fabrications of the truth?
In any event from what you say this indeed does seem OK, and is quite reasonable actually, in my shop it would cost about the dame if not slightly more! In reality that under $300.00 repair is quite low in the big scheme of things this is why, these days replacement is a better option, in nearly all cases unfortunately.
May I add that just because the customer "Thinks" that they have "Sussed" the problem in actuality may NOT be correct and often the most seemingly simplest problems are indeed quite bad. I say have more faith in the people you use> If you want satisfaction one MUST take any repair to the authorised service centers, usually one recommended by the manufacturer or agent, simply contact them and ask for a referral and go from there, as usual ONLY ever first ask for a "Quote".
Posted on Oct 15, 2011
There is no sound in my laptop
1. Check the volume settings of the computer.
2. Try connecting external headphones to check if there is any error with internal speakers.
3. Reinstall Audio drivers and its updates.
4. Click on Start, Control Panel >Hardware and sound.
5. Open sound properties windows and in the playback devices tab, check if the internal speakers/HP option is selected as the default audio device.
Note: VPCEB series computers have a known issues with the internal speakers. The best option is get the internal speakers replaced for EB series.
Prove exact model of your Sony VAIO notebook for a more precise reply.
Jun 03, 2011 | Sony VAIO Notebook
Other person can't see me on their side
Try tuning on the AEC(Acoustic Echo Cancellation)
AEC or echo canceling can be toggled on and off via the QuickCam interface.
QuickCam 9:
Toggling AEC on and off (Windows® XP Users)
1. Go to "Start" and select "Control Panel"
2. In the "Control Panel" locate and click the "Logitech Camera Settings" icon
3. Click the "Audio" tab and locate the "Enable AEC" check box
Toggling AEC on and off (Windows® 2000 or XP Classic Mode Users)
1. Go to "Start" select "Settings" and click "Control Panel"
QuickCam 10/11:
Toggling AEC or "Echo Canceling" on and off
1. Open the QuickCam main menu
2. Locate and click the "Change Settings" button
3. Click the "Audio Settings" button
4. Check or uncheck the "Cancel Echo" option
Call Central:
1. Open the Call Central main menu
Yo can try the audio tuning :
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=2835&p_created=1124146188&p_sid=_KquRy3j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTUsMTUmcF9wcm9kcz04NDQsNSw4OTcmcF9jYXRzPSZwX3B2PTMuODk3JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9YXVkaW8gbm90IGNsZWFy&p_li=&p_topview=1
Or
http://tinyurl.com/45ay9b
Update the Skype & the drivers for your webcamera.
May be there is lot of disturbance in the medium.
And i am giving you the lnks which can help you :
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=7287&p_created=1193078628&p_sid=_KquRy3j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9ODQ0LDUsMTkxMyZwX2NhdHM9JnBfcHY9My4xOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9cGljdHVyZSBxdWFsaXR5&p_li=&p_topview=1
Or
http://tinyurl.com/3teqez
and
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=54&p_created=1083862182&p_sid=_KquRy3j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9ODQ0LDUsMTkxMyZwX2NhdHM9JnBfcHY9My4xOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9cGljdHVyZSBxdWFsaXR5&p_li=&p_topview=1
Or
http://tinyurl.com/4ff4bn
and
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=58&p_created=1083864116&p_sid=_KquRy3j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9ODQ0LDUsMTkxMyZwX2NhdHM9JnBfcHY9My4xOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9cGljdHVyZSBxdWFsaXR5&p_li=&p_topview=1
http://tinyurl.com/42hd7t
Hope this helps.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 30, 2010 | Gear Head WC535I Webcam
Our new 6.0 Caller ID phones have an echo. Can you suggest a remedy? John Chalk johnchalk@hotmail.com
as per jonniewalker from one of his posts:
"it may be due to interference from electronics devices around you since its a cordless phone ,or your phone is not getting a complete connection, could be one cause,Please try these solutions when you experience echo sound :
- turn the volume down
- turn the "clarity booster" function on the phone
Follow these steps to turn on clarity booster
1) Press menu/del during talk time (while phone is in use).
2) Press ^/vol or vol/v to move the pointer to Clarity Boost, and then select Boost On and "B" appears on the display. To turn Off the Clarity Booster, repeat above step again. check the owners manual for a full description for your model of phone
*Please note: clarity booster turns off automatically at the end of each call.
- make sure the Echo Canceller Circuit (ECC) has been set properly
*The phone should have Echo Canceller Circuit (ECC) built in.
*This means the circuit will study the Voice Level & reduce/cut the echo automatically.
Follow these steps to set the ECC properly
1. Unplug the battery from the handset for a few seconds.
2. Re-plug the battery back into the handset.
3. Make a phone call & at the initial stage speak loudly into the mic. Please note: The ECC will learn at the initial stage only, so after these steps are followed, the ECC will start working properly.or
just a simple pwr cycle ( turning the phone off) can give you a fresh registratoin, this can improve the quality of the call. hope this helps pls do let me know"
Feb 11, 2010 | Panasonic (KX-TG1032S) Phone
Sony CDX-S2210 CD Player stuck on demo mode , cant adjust volume eq, skip track or anything
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Jan 28, 2010 | Sony CDX-S2210 CD Player
Echo on my end when someone calls! Please help! Thanks!
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
Zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Apr 05, 2009 | Yamaha RX-V661 Receiver
Sony PCS-1 dont remember admin password
PUSH ENTER button).
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
PCS-1
PUSH ENTER button).
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
check for your lan settings, try to see if there is no nat on one of your network make the nat settings
Jan 11, 2008 | Sony PCS-1 (PCS1) Video Conference
Fax thru pap2
NOTE: Set the following parameters under Line 1 or Line 2 tab, depending on what Line the fax is registered to.
Step 1:
Access the PAP2’s web-based setup page.
Step 2:
Once the PAP2’s web-based setup page appears, click Admin Login then click switch to advanced view.
Step 3:
Click Line 1 or Line 2.
5185-003.png Step 4:
Look for Network Settings set Network Jitter Level to high.
5185-005.png Step 5:
Go to the Audio Configuration section and set Silence Supp Enable, Echo Supp Enable and No Echo Canceller to no. Set FAX Passthru Method to NSE, FAX Passthru Codec to G711u and Use Pref Codec Only to yes.
5185-007.png Step 6:
Go to the Supplementary Service Subscription section and set Call Waiting Serv and Three Way Conf Serv to yes.
5185-009.png NOTE: If the above settings did not work, please power down the PAP2 and power it on after 30 seconds.
Step 3:
Nov 30, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Sony PCS-1 (PCS1) Video Conference Logo
98 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
