Question about Honeywell Heating & Cooling
My boiler most of the time don't star until I push the switch in the pressuretrol (honeywell) PA404A1033. After I activate the turn on and off regular for some hours but later again don't star until I pushed the pressure switch. Please let me know what can I do.
    Champion:
  • 254 Answers
Looks as if your boiler is over firing (extended run) you probably have a faulty sensing thermostatic probe causing this the switch you are resetting is a safty pressure switch it is designed to keep the pressure from building which could cause the boiler to explode.
Posted on Nov 15, 2008
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
Its a honeywell amptec boiler c1200 95 022 055 gc no eb-205-04
The red light turns off on the timer unit, but the boiler keeps going. Thanks for the informative post.
Do you need a 1300 number?
Nov 10, 2012 | Honeywell Aube by TI0323WU 7Day...
Ariston microcombi 23 mffi Boiler Manuals
its the air pressure switch. needs replacing. they are quite cheap but it could be something a little more expensive but you wont know until you replace it. easy half hour fix
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
Hhow to set the pressuretrol??
I assume you are talking about a steam heating system...
There are two screws on the top of the pressuretrol...
turn the pressure screw down to the lowest pressure at which you still get heat to the farthermost radiator...make sure the vents are working...or steam does not flow to displace the air...
Then just give the differential screw enough difference so the boiler cycles on and of a bout three times and hour...when making steam...
That's all there is too it...
heatman101
Oct 08, 2010 | Heating & Cooling
Hot Water But No Heat In The Radiators
bleed radiators and check for dirty flame sensor and clean it with steel wool
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Hello, I have a Worcester 24i boiler, it has a round clock with a grey outer ring,that can be pushed in(the grey bits around the clock), I would like to know how to set the timer on this boiler, it's...
When the grey bits are pushed in the boiler is set to come on for that 15 min incriment. Push they grey pins "in" for the required length of time you want the heating on and then set your manual on off switch to the middle position which will activate the clock to run through the set time sequence you have put in.
Sep 30, 2009 | Heating & Cooling
Baxi boiler timer
1)Push all the little pins (bits) inward toward the centre of the dial
2)Set timer to correct time by
turning dial to current time, ie if present time is 4.00 p.m.
Turn the dial until 4.00 p.m is aligned with the arrow symbol
3)PULL OUT all the ( bits) toward the outer edge of the dial to set the time that you want the heating to come on .eg pull out all pins between 6.00am and 9.00am(as each pin represents 15 minutesyou should have 12 pins pushed out)
4) Ensure the3 way switch in the middle of dial is in the middle position(timer) if it is at top position boiler is(constant on)and at bottom positon boiler is turned off.
Feb 02, 2009 | Hardware & Accessories
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
I have a honeywell PA404A pressure control switch on my home gas steam heating system. I'm having a problem with the switch turning off the system. It will only come back on if I turn the top screw all the...
This may be caused by accumulation of sludge in the steam trap (the looped tube that connects the pressuretrol unit to the boiler). the sludge restricts the pressure from reaching the diaphragm in the pressuretrol unit. So it gets a false reading. Clean or replace the tube and see if normal function resumes.
Jan 06, 2009 | Heating & Cooling
Heating & Cooling Logo
111 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
