Question about GE 24-7/8" Convertible Portable Dishwasher - White-on-White
Hose does not fit on sink faucet
I got a new faucet put on my kitchen sink. i just realized that the hose from my convertible dishwasher will not attach to my new faucet. is there some kind of an adapter i can purchase?
thank you.
  • 3 more comments
  • Anonymous Dec 01, 2008
    my dishwasher does not fit my faucet what do i need to get it to work it is a ge nautilus portable dishwasher
  • Anonymous Dec 12, 2008
    me too.
  • NachoCamacho Dec 16, 2008
    I have a Kenmore Portable Dishwasher given to me by a friend who just bought a house. The hose from the dishwasher does NOT fit on the sink faucet either. The hose is much larger than the sink faucet. HELP!!! Thanks.
  • David Sisk
    David Sisk Aug 27, 2013
    I got a problem with my portable dishwasher and portable washer, the dishwasher's Faucet Adaptor is too small for the washers Faucet Adaptor how can I fix this?
  • michelle Sep 01, 2013
    I got a set of adapters from Amazon. they are to make your dishwasher connector able to adapt to different size faucet threads! saved the day!
Yes, the adapter was the answer!!! I went to the Sears Service Center and bought one, under $10. HURRAY! And say hello to softer hands . . .
Posted on Feb 15, 2009
  • David Sisk
I have a small adapter that came with my dishwasher. you unscrew the aerator from the faucet and screw in the adapter. maybe you need one of those.
Posted on Jan 17, 2009
Hose/ Adapters for older Maytag Portable Dishwasher
The sink faucet may have to be modified by installing an adapter.
Jun 22, 2017 | Maytag Dishwashers
Why does my locking collar from my unicouple hose not fit on my kitchen sink faucet/
Go to a plumbing store where the contractors
go & get the correct adaptor
Sep 28, 2014 | Plumbing
How remove handle for water ridge farcet nsf 61/9
On a water ridge kitchen faucet, there is a brass fitting that the water supply hose going to the faucet you pull out connects to under the sink, on that fitting youll find a small screw loosen it up, pull the fitting off , also loosen the other screw and disconnect the hose, now look inside the fitting there is some plastic junk ( not sure what its for) get a screw driver and a hammer and bash it out(not to hard) then put it back together. good to go, full pressure!! worked on mine and has for 2yrs.
Oct 20, 2012 | Plumbing
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
How do i replace the hose
There is never a lot of room between the wall and the sink. I found it easier to remove the faucet unscrew the hose and put the new one in place
PS don't forget to turn the water off
andrew
Jun 09, 2012 | Grohe 32 999 KD0 Alira Pull-Out Spray...
The entire faucet is lifting off and spraying water at the joint when the lever is activated and water is being used,do I need to call a plumber to repair this. It seems that the faucet cannot be screwed...
No you do not need a plumber,
below under the sink, there are two valves, One for Hot ,One for Cold.
Turn them to the right.make sure they are turn all the way with a little pressure at the end. Now the kitchen has no water.
With a wrench ot pliers remove the water hoses, There may be a little water left in the hose so don't panic.
Now this may be a little harder.
Put yourself all the way under the sink,with you on your back.
Do you see the taps. There may be a fitting with screws. remove screws and fitting. You should be able to remove the whole Tap.
With you new tap... Follow their instruction.
When you are putting the hoses back on.. make sure they are slightly snug.
We don't want it to leak again.
Turn you water back on and slowly turn on your taps.
Aug 05, 2010 | Rohl A3608LMAPC Single Lever Country...
Grohe ladylux plus kitchen faucet leaks from multiple points along metal pull out hose attached to faucet head. Is this fixed by replacement of same hose? How do I replace the hose?
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Feb 23, 2010 | Grohe Plumbing
How do i connect a kenmore ultra wash II portable dishwasher to kitchen sink, the attachement on the hose attached to the dishwasher it to big around to fit my facuet
You can get an adapter from a local hardware store. I'd come equipped with make and model number and the screw on screen retainer piece from your faucet.
Aug 21, 2009 | Dishwashers
I have a new hose for my Grohe Euro Plus to replace a leaking old one. I have disconnected it from the water supply but now the ends of the the old hose will not fit through part connected to the sink...
There are 2 sets of nuts and washers underneath the faucet that holds the faucet in place. loosen them and the water lines (after turning the water off) faucet lifts off from the top of the sink. Replacement the the same, just in reverse. BE SURE TO USE TEFLON TAPE OR PLUMBERS PUTTY ON THE WATER LINE THREADS TO PREVENT COSTLY LEAKS.
Jun 20, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
GE 24-7/8" Convertible Portable Dishwasher - White-on-White Logo
2,008 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
